1998 Toyota Altezza RS200 Zed
jimlee
Posted: September 18, 2004 at 6:12 AM / IP Logged
I am required a Alarm and CD unit information, Please help me if you know, Cheers!
~~~~~Fly Bus ====== Altezza~~~~
Platinum - Posts: 12,488
Posted: September 18, 2004 at 8:40 AM / IP Logged
Here is all the information available for the 1999 Lexus IS200 which is the same as the Toyota Altezza:
|              12V|BATTERY
|          STARTER|BLACK/ white         |   |ignition harness            |
|         IGNITION|BLACK/ red           |   |ignition harness            |
|        ACCESSORY|red                 |   |ignition harness            |
|       POWER LOCK|GREEN/ YELLOW        |5wi|wht plug driver kick panel  |
|     POWER UNLOCK|RED / white           |5wi|wht plug driver kick panel  |
| PARKING LIGHTS +|grn/yel & grn/blk   |   |driver kick panel           |
|     DOOR TRIGGER|RED / white           |-  |at B post or interior light |
|  TRUNK/HATCH PIN|RED / yellow          |   |alarm in driver kick panel  |
|       TACHOMETER|BLACK/ silver dots   |   |diag. plug under driver dash|
|       BRAKE WIRE|GREEN / WHITE         |   |brake pedal switch          |
Notes:
*1 Mirror fold - GREEN/ red and green, reverse polarity. Both wires are open circuit so supply ground and 12 volt at the same time. To fold back out reverse connection.
jimlee
Posted: September 19, 2004 at 1:25 AM / IP Logged
Cheers Man~~
Wednesday, January 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
