2004 Ford Explorer Alarm/Remote Start Wiring
tek1000
Member - Posts: 13
Posted: October 13, 2004 at 6:35 PM / IP Logged
 any body the diagram 2004 explorer for alarm with remote start.
mo12v
Posted: October 13, 2004 at 6:41 PM / IP Logged
This is what I have:
Can use OMEGA # IB-PKF-3  (no key) Transponder
Constant 12 voltsYELLOWIGNITION SWITCH HARNESS
Ignition 12 voltsRED / GREENIGNITION SWITCH HARNESS
StarterREDIGNITION SWITCH HARNESS
Dome LightBLACK/ LT.BLUE (+)*DRIVER KICK PANEL
Trunk Pin SwitchWHITE/ VIOLET (-)AT C.S.M**
Parking LampBROWN (+)AT HEADLIGHT SWITCH
Power LockPINK / YELLOWDRIVER KICK PANEL***
Power UnlockPINK/GREENDRIVER KICK PANEL
* Late Built Found As LT.GREEN/ ORANGE (+) In Drivers Kick Panel ** The Central Security Module- Behind Right Rear Quarter Panel ***
Negative Pulse Door Locks
Accessories
Window UpD/F\ WHT/BLK
P/F\ WHT/YEL
D/R\ YEL/BLU
P/R\ BRN/YEL @MAIN SWITCH
Window DownDF/ TAN/BLU PF/ TAN/BLU D/R/ YEL/BLK D/R/ BROWN
Ign Key WarnBLACK/ PINK (+)IGNITION SWITCH HARNESS
Trunk ReleaseVIOLET / YELLOWAT TRUNK RELEASE SWITCH
OEM HornYELLOW/LT.GREEN (-)IGNITION SWITCH HARNESS
HeadlightsRED / YELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmGREEN/ VIOLET (-)DRIVER KICK PANEL
 Reversal Rest At Ground Power Window Circuit
Negative Pulse Trunk Release Circuit
OEM Alarm Horn Wire- DARK BLUE (+) At Factory Horn OEM Alarm Hood Trigger-TAN/LT GREEN (-) At Switch Under Hood
Remote Start
Tach SignalTAN/WHITE 4.0 LITERAT IGNITION COIL*
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3
AccessoryD GREEN/ LT.GREENIGNITION SWITCH HARNESS
Neutral Safety
Brake LightRED / GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (+)IN HARNESS FROM GAUGES
Rear Window DefrostBROWN / LT.BLUE (+)AT REAR DEFROST SWITCH
*RED / Blue 5.0 Liter At Ignition Coil
Immobilizer Bypass
MO
snguyen
Silver - Posts: 281
Posted: October 13, 2004 at 7:42 PM / IP Logged
EXPLORER 2002- 2004
WIRE COLORSLOCATION
12 VOLTS CONSTANT
YELLOW
IGNITION 1RED / GREEN (+)IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER DARK GREEN/ LIGHT GREEN (+)IGNITION SWITCH HARNESS
STARTERRED (+)IGNITION SWITCH HARNESS
PARKING LIGHTS (+)BROWN or WHITE/ BLACKat HEAD LIGHT SWITCH or at the VSM See NOTE***
DOME LIGHTBLACK/ LIGHT BLUE (+)in DRIVERS KICK PANEL in harness heading to rear of vehicle.
POWER DOOR LOCKPINK / YELLOWlocated in DRIVERS KICK PANEL in the DOOR HARNESS or at the VSM (TYPE "B") See NOTE***
POWER DOOR UNLOCKPINK/ GREENlocated in DRIVERS KICK PANEL in the DOOR HARNESS or at the VSM (TYPE "B") See NOTE***
TACH SENSORTAN / YELLOWat the PCM, located at the TOP of the FIREWALL, passengers side. This wire can also be found at the back of the Instrument cluster.
TRUNK/HATCH RELEASEORANGE / LIGHT GREEN or PURPLE / YELLOW (+)at the VSM See NOTE***
BRAKE
TAN/BLACK to LIGHT GREEN (+)at SWITCH on BRAKE PEDAL BRACKET
HORN
YELLOW/LIGHT GREEN (+)
in STEERING COLUMN HARNESS
FACTORY ANTI-THEFTTRANSPONDER (Ford's SecuriLock) Requires part #791 bypass module and extra ignition key.
NOTE*** The VSM (Vehicle Security Module) is located in the PASSENGER SIDE REAR QUARTER PANEL below the "C" PILLAR.
snguyen
Silver - Posts: 281
Posted: October 13, 2004 at 7:44 PM / IP Logged
Ford
Explorer
2002-2004
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED
IGNITION SWITCH HARNESS *
Ignition #1:
RED / GREEN
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
GREEN/ LT. GREEN (SMALL)
Brake Light:
LT. GREEN
Tach Signal:
BLUE/GREEN
AT COIL PACK
Parking Lights:
BROWN (+)
AT SWITCH OR DRIVER'S KICK PANEL
Headlights:
OEM Alarm Disarm:
GREEN/ PURPLE (-)
DRIVER'S KICK PANEL
OEM Alarm Arm:
N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* This Vehicle Is Equipped With Ford's PATS Anti-Theft System. Use Universal Alarm Bypass Module or See Installation Note #144 - Bypassing Transponder Theft Systems. ** Use This Wire For Door Trigger Only. For Dome Light Supervision, Use BLACK/ Lt. Blue (+ 12 Volt Trigger) Located In Driver's Kick Panel. ****All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the 'control harness.' This wire will be used to control the bypass module, if needed. Note: 2003 may have smaller awg ignition wires.
Ford
Explorer
2002-2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
YELLOW
Starter Kill:
RED
Ignition +12 Volts:
RED / GREEN
Dome Lights/Superv:
LT. BLUE/WHITE (-)
INSTRUMENT CLUSTER **
OEM Horn:
YELLOW /GREEN (-)
Power Lock:
PINK / YELLOW (-)
DRIVER'S KICK PANEL***
Power Unlock:
PINK/GREEN (-)
DRIVER'S KICK PANEL
Trunk Release:
N/A
Alarm Input Wire:
LT. BLUE/WHITE (-)
Notes:
*** See Note #201 Negative Trigger Door Locks
Saturday, January 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
