dodge ram 2001 diesel/quad :hid light conversion
ck7560
Posted: October 01, 2002 at 6:19 AM / IP Logged
The HID Lighting conversion kits require that you know what is :
a) Low Beam
b) High Beam
c) Negative
Please tell me what the wiring is what at the 9004 female pin connector.
user
carguy411
Silver - Posts: 683
Posted: October 01, 2002 at 11:48 AM / IP Logged
if u have a circuit tester or a MM just test the wires its that easy
Platinum - Posts: 12,488
Posted: October 01, 2002 at 4:19 PM / IP Logged
From the notes that I have the bulbs is a 9007 bulb. Here is the bulbs size chart for the truck : http://www.sylvania.com/bin/carApp/carApp_ver2.pl?flag=model_quals&make=&make=Dodge&year=&year=2001&model=Ram+Pick-up&x=24&y=5
ck7560
Posted: October 07, 2002 at 3:07 AM / IP Logged
HELP !
The 2001 DODGE RAM has reversed polarirty switching ?
How can I install a relay to make the HID's work ??
The HID wants a power, then negative for Low or HIGH, the Dodge just has positives.
user
Posted: October 07, 2002 at 9:45 AM / IP Logged
  • POSITIVE INPUT -----> POSITIVE OUTPUT
    • 87 - constant 12 +
    • 86 - Chassis Ground
    • 30 - Output 12 +
    • 85 - low current positive
    • 87a- NOT USED
  • NEGATIVE INPUT----> NEGATIVE OUTPUT
    • 87 - Chassis ground
    • 86 - constant 12 volts +
    • 30 - GROUND output
    • 85 - low current ground input wire from a device
    • 87a - NOT USED
  • POSITIVE INPUT ----> NEGATIVE OUTPUT
    • 87 & 86 -  CHASSIS ground
    • 30 - Ground OUTPUT
    • 85 - 12 volt INPUT
    • 87a - NOT USED
  • NEGATIVE INPUT ----> POSITIVE OUTPUT
    • 87 & 86 - 12 volts +
    • 30 - 12 volts OUTPUT
    • 85 - Ground INPUT
    • 87a - NOT USED
  • Jeff
