2002 Honda Accord SE Coupe 4 Cyl
HavocsHonda
Posted: October 31, 2004 at 12:00 PM / IP Logged
Ive been looking everywhere for a wiring diagram for my 2002 honda se coupe but i cant find it, haynes doesnt have a manual out for the 2002s yet so i couldnt get any help there. I need some info on the fuse box and how to take out the dash and a wiring diagram, appreciate it alot cuz ive been searching for almost a week now. Thanks
mo12v
Posted: October 31, 2004 at 3:38 PM / IP Logged
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH AHRNESS *
Dome LightBLACK/ WHITE (-)4 PIN CONN. IN PASSENGER FUSE BLOCK
Trunk Pin SwitchORANGE (-)18 PIN CONN. IN DRIVER KICK PANEL
Parking LampRED / BLACK (+)GREEN 20 PIN CONN. DRIVER FUSE BLOCK
Power LockBLACK/ WHITE2 PIN GRAY CONNECTOR IN
Power UnlockGREEN/ REDDRIVER KICK PANEL (LX MODEL) **
* Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block. **EX Model Access Door Locks At Passengers Side Multiplex 20 Pin GREEN Con Unlock BLU/ORN (-) Pin 4 Lock BLACK/ ORANGE(-)Pin 16.Behind Lower Cover.
Negative Pulse Door Locks
Accessories
Window UpD\ RED / YEL P\ BLU/WHT RED / BLU P\ RED / BLU @ EACH SWITCH*
Window DownF/ RED / BLU F/ BLU/YEL R/ RED / YEL R/ RED / YEL  *
Ign Key WarnBLUE/WHITE (-)IGNITION SWITCH HARNESS
Trunk ReleaseGRN/BLU (-) AT KEYLESSMODULE (LX), WHT/RED (+)(EX)****
OEM HornLIGHT GREEN/ BLUE (-)STEERING COLUMN HARNESS **
HeadlightsBLUE/RED (-)HEADLIGHT SWITCH
OEM Alarm ArmSEE TECH ON IGNITION DISABLE
OEM Alarm DisarmORANGE (-)BEHIND GLOVE BOX IN 24 PIN CONNECTOR
* Due To Multiplexing Window Wires Must Be Accessed At Each Window Switch But All Are Reverse Rest At Ground Type Circuits. ** Horn Wire Can Also Be Found At GREEN 16pin Connector AT Passenger Fuse Box. *** Disarm Can Be Found As BLUE (-) At Driver Multiplex Unit (Door Switch). **** Located At Pass Multiplex Control Unit Behind Right Side Glove Box. Reversal Rest At Ground Window Circuit
Remote Start
Tach SignalBLUEWHT 2 PIN TEST CONN-PASS REAR ENGINE*
Ignition #2YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryWHITE/ BLACKIGNITION SWITCH HARNESS
Neutral SafetyBLUE/WHITE (-)GREEN 20 PIN CONN DRIVER FUSE BLOCK
Brake LightWHITE/ BLACK (+)SWITCH ABOVE BRAKE PEDAL
Reverse LightGREEN/ BLACK (+)GREEN 10 PIN CONN DRIVER FUSE BLOCK
Rear Window DefrostBROWN / YELLOW (-)REAR DEFOGGER SWITCH
 Immobilizer Bypass
. * 4 Cylinder Models- 6 Cylinder Models Connector Is On Driver Rear Of Engine
MO
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
