2001 Ford Escape Alarm/Remote Start Wiring
RebelShadow
Posted: November 06, 2004 at 7:27 PM / IP Logged
Hi,
Does anyone have the wiring diagram for a 2001 Ford Escape. I am trying to install a remote start / car alarm. Thanks in advance!!!
mo12v
Posted: November 06, 2004 at 10:07 PM / IP Logged
Constant 12 voltsRED / L BLUE *IGNITION SWITCH HARNESS
Ignition 12 voltsL GREEN/ VIOLETIGNITION SWITCH HARNESS
StarterTAN/L BLUEIGNITION SWITCH HARNESS
Dome LightL GREEN/ ORANGE (-)PIN 1 OF GEM MODULE **
Trunk Pin SwitchWHITE/ VIOLET (-)PIN 18 OF GEM MODULE **
Parking LampBROWN (+)CENTRAL JUNCTION MODULE IN DR. KICK
Power LockPINK/WHITE **AT GEM MODULE OR
Power UnlockUNDER CENTER CONSOLE ***
* RED / L BLUE At Ignition Switch Fused At 10 Amps. Connect High Current Devices Directly To Battery Or YELLOW Wire At Fuse Box Which Is Fused At 40 Amps. ** GEM Module Located Behind Center Of Dash At Floor Level. See Tech Notes! *** Single Wire Door Lock System. PINK/WHITE Wire Requires Chassis Ground To Unlock Doors And Chassis Ground Thru A 1000 Ohm Resistor To Lock Doors.
Single Wire Resistor Door Locks
Accessories
Window UpD\ WHT/BLK P\ WHT/YEL D\ RED / BLK P\ YEL/BLU @ MAIN SWITCH
Window DownF/ RED F/ TAN/BLU R/ YEL/BLK R/ GRY/ORG
Ign Key WarnBLACK/ PINK (+)STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornYELLOW/L GREEN (-)AT STEERING COLUMN HARNESS
HeadlightsRED / WHITE (-)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmBLUE/GREEN (-)AT GEM BEHIND LOWER CENTER OF DASH
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalD GREEN/ VIOLETAT COIL PACK OR PCM UNDERHOOD *
Ignition #2N/A
Ignition #3N/A
AccessoryBLACK/ L GREENIGNITION SWITCH HARNESS
Neutral SafetyNONE GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightL GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (-)IN DRIVER KCIK PANEL
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Wire Can Be Found In PIN 26 Of PCM In 4 Cylinder Engine. Wire Can Be Found In PIN 52 Of PCM In V6 Engines.
Immobilizer Bypass
MO
RebelShadow
Posted: November 07, 2004 at 5:17 AM / IP Logged
Thank you VERY VERY much. I know what I'm now doing this weekend :-)
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
