2004 Mazda Tribute wiring diagram
Pacmann
Member - Posts: 6
Posted: December 10, 2004 at 11:50 PM / IP Logged
I need it mainly for the lock and unlock wires. thanks
tommy...
Gold - Posts: 1,901
Posted: December 11, 2004 at 9:18 AM / IP Logged
[PRINT THIS PAGE]
12volts RED / lt. blue (10A)  +  ignition harness
Starter tan/lt. blue  +  ignition harness
Second Starter N/A
Ignition lt. GREEN/ purple  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ lt. green  +  ignition harness
Second Accessory N/A
Keysense BLACK/ pink  +  ign harn or GEM, 22 pin plug, pin 6
Notes: The GEM (Generic Electronic Module) is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the driver side of the vehicle.
Power Lock pink/white  -  DKP or GEM, 26 pin plug, pin 23
Notes: Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
Power Unlock same wire as power lock
Lock Motor pink/black  5wi DKP or GEM, 26 pin plug, pin 13
Unlock Motor RED / orange  5wi DKP or GEM, 26 pin plug, pin 25
Parking Lights+ brown  +  driver kick, harness to rear
Parking Lights- BLACK/ lt. green  -  switch or GEM, 22 pin plug, pin 4
Hazards WHITE/ red  -  switch or GEM, 22 pin plug, pin 9
Turn Signal(L) ORANGE / black  +  steering column
Turn Signal(R) BROWN / white  +  steering column
Reverse Light BLACK/ pink  -  driver kick, harness to rear
Door Trigger PURPLE / lt. green  -  cluster or GEM, 22 pin plug, pin 10
Dome Supervision lt. GREEN/ orange  -  dome lt or GEM, 26 pin plug, pin 1
Trunk/Hatch Pin common with door trigger
Hood Pin PURPLE / orange  -  pin sw or GEM, 22 pin plug, pin 16
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm WHITE/ purple  -  DKP or GEM, 26 pin plug, pin 20
Factory Alarm Disarm dk. blue/lt. green  -  DKP or GEM, 26 pin plug, pin 19
Disarm No Unlock see factory alarm disarm
Tachometer NOT WHITE/ purple or red  ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green  +  brake pedal switch
Parking Brake lt. GREEN/ red  -  parking brake switch
Horn Trigger YELLOW /GREEN  -  column or GEM, 22 pin plug, pin 19
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2004 Mazda Tribute wiring diagram -- posted image.
Immobilizer Bypass Module:Required: YesType: SecuriLockPart #: 555S, 556U, or 555U
Notes: Use the BLACK/ pink (+) key sense wire at the ignition harness to interrupt the blue wire on the 555S or 555U so that when the key is inserted to do take over the vehicle does not see two transponders at the same time. Refer to DirectFax document 1079 for wiring information.
M.E.C.P & First-Class
tommy...
Gold - Posts: 1,901
Posted: December 11, 2004 at 9:20 AM / IP Logged
sry so long...hope this helps...will try to format different next time...
Pacmann
Member - Posts: 6
Posted: December 11, 2004 at 10:30 PM / IP Logged
Hey thanks helps out alot.
