04 Silverado Duramax Remote Start
TheevesLLC
Member - Posts: 41
Posted: December 12, 2004 at 8:40 PM / IP Logged
Hello, does anybody know any alarm security info for an 04 duramax diesel?
i can probably figure out all the ignition wires and whatnot, but i don't know where to start for the wait-to-start wire other than ripping the gauges out.
think the 2000 silverado duramax would be a good point of reference?
Thanks,
Connor
dantemc
Member - Posts: 25
Posted: December 12, 2004 at 11:58 PM / IP Logged
hey connor, as with most new cars, the wait to start wire is difficult to find. its not worth tearing the car apart, the easier solution which works perfect would be a dei pulse timer. its a relay that you basically hook up to the alarm's wait to start, and it will show ground for as long as you program it for, then it shuts down, and the car starts. its a simple hook up, and after a few tries, you can get it to turn off and start as soon as the check bulb turns off. i have done that car recently, and the wiring diagram for it was incorrect, so i just used the pulse timer, it worked out fine.  hope that helps
TheevesLLC
Member - Posts: 41
Posted: December 13, 2004 at 12:11 AM / IP Logged
that sounds good to me, but what about those cold mornings where it takes particularly long to warm the glow plugs?  i don't want it to crank before it's ready, but i'm sure this guy isn't gonna want to wait 10 seconds everytime he hits the button.  are the rest of the connections pretty simple?
i hear i'll also need a 555L and a 456G, i've never done a GM-VATS/passlock system before, though i've done more remote starts in general than i care to count.  is it difficult?
thanks for your help
connor
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
