05 Dodge Dakota Alarm/Remote Start Wiring
larkster
Copper - Posts: 98
Posted: December 30, 2004 at 10:19 AM / IP Logged
anybody have any info on this truck  im starting one now and have tons to do today so any help would be great.
thanks
snguyen
Silver - Posts: 281
Posted: December 30, 2004 at 11:10 AM / IP Logged
Dodge
Dakota
2005
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
Pink/lt.blue
IGNITION SWITCH HARNESS
Ignition #1:
Pink/lt.green
Ignition #2:
Dk.blue
Ignition #3:
Pink/white
Accessory:
Pink & pink / YELLOW
Brake Light:
WHITE/ lt.blue
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
Not red
AT IGNITION COIL *
Parking Lights:
Pink/red (-)
switch. Ground through 1130 ohm resistor. Must use relay
Headlights:
N/a
N/a
Diesel Glow Plug:
N/a
Clutch Bypass Wire:
N/a
Notes:
Must Use relays for parking lights
Dodge
Dakota
2005
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
red & RED / lt.blue
OEM Alarm Disarm:
Factory remote only
Dome Lights/Superv:
Yellow/orange (+)
Behind insturment cluster. Must use relay
OEM Horn:
Dk.GREEN/ purple (-)
(-) STEERING COLUMN HARNESS
Power Lock:
PURPLE / green (sw)
Ground through 330 ohm resistor. Must use relays
Power Unlock:
same as lock
Ground through 100 ohm resistor. Must use relays
Trunk Release:
N/A
Alarm Input Wire:
Yellow/orange (+)
Notes:
Only way to disarm vehicles alarm is with factory remote only
larkster
Copper - Posts: 98
Posted: January 13, 2005 at 9:58 AM / IP Logged
im looking for information on doing door locks and disarm on this truck any help would be great
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
