wire diagram
Nastyboy715
Posted: October 20, 2002 at 5:56 AM / IP Logged
i need a wire diagram on my 93 honda civic 2dr coupe so i can install an alarm with remote starter and keyless entry
Moderator - Posts: 12,488
Posted: October 20, 2002 at 8:36 AM / IP Logged
|              12V|white               |+  |brn conn abv fusebox        |
|          STARTER|BLACK/ white         |+  |brn conn abv fusebox        |
|         IGNITION|BLACK / YELLOW        |+  |brn conn abv fusebox        |
|        ACCESSORY|yellow              |+  |brn conn abv fusebox        |
|       POWER LOCK|GREEN / WHITE         |-  |in drivers door *2          |
|     POWER UNLOCK|GREEN/ red           |-  |in drivers door *2          |
| PARKING LIGHTS +|RED / black           |   |grn plug top of f-box       |
| PARKING LIGHTS -|WHITE/ black         |   |anti-theft module *3        |
|       HEADLIGHTS|RED / white (low only)|+  |steering column             |
|     DOOR TRIGGER|lt GREEN/ red        |-  |driver kick panel           |
|  TRUNK/HATCH PIN|grn/blk 2 silv dots |-  |blu conn above fusebox      |
|  FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|blue *1             |   |2-pin plug near distr.      |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|blue/green *4       |-  |steering column             |
|           WIPERS|blu(low),blu/yel(hi)|-  |wiper switch                |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |in drivers door             |
|  RF WINDOW UP/DN|blu/yel - blu/grn   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|grn/yel - green     |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |in drivers door or dkp      |
Notes:
*1 Also at round gray connector next to hood strut.  *2 Door lock module in door above the speaker.  the wires can also be found at the anti-theft if equiped.   *3 the anti-theft module is located under the drivers seat.  only some models are equiped with anti-theft.  *4 can also be found blue/red at anti-theft if equiped
