2002 nissan sentra remote start
nugent
Member - Posts: 9
Posted: January 19, 2005 at 1:47 PM / IP Logged
2002 nissan sentra remote start and door lock schematics. please help i don't want a fire. thanks.
mo12v
Posted: January 19, 2005 at 6:32 PM / IP Logged
Constant 12 voltsWHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightRED / WHITE (-)20 PIN CONNECTOR IN DR. KICK PANEL *
Trunk Pin SwitchRED / BLACK (-)AT LIGHT IN TRUNK **
Parking LampWHITE/ RED (+)AT HEADLIGHT SWITCH
Power LockGRAY16 PIN CONNECTOR
Power UnlockPURPLE / REDIN DRIVER KICK PANEL
* With Power Locks Doem Light Can Be Found As RED (-) And RED / WHITE At "Smart Entry Control Timer" Behind Driver Dash. ** With OEM Alarm: RED / BLACK (-) Trunk Wire Also Located At "Smart Entry Control Timer" Behind Driver Dash
Negative Pulse Door Locks
Accessories
Window UpD\ GRN/RED P\ RED / WHT D\ YELLOW P\ GRN/WHT @ MAIN SWITCH
Window DownF/ BLUE F/ RED R/ YEL/BLU R/ GREEN
Ign Key Warn
Trunk ReleaseRED (-)AT TRUNK RELEASE SWITCH
OEM HornWHITE/ GREEN (-)STEERING COLUMN HARNESS
HeadlightsRED / YELLOW (DR) &VIOLET (PS) (+) AT HEADLIGHT SW.
OEM Alarm ArmL GREEN/ RED (-)AT "SMART ENTRY CONTROL UNIT"
OEM Alarm DisarmWHITE/ BLUE (-)LOCATED BEHIND DRIVER DASH
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalRED STRIPEAT ENGINE CONTROL MODULE *
Ignition #2
Ignition #3
AccessoryWHITEIGNITION SWITCH HARNESS
Neutral Safety
Brake LightRED / GREEN (+)AT BRAKE SWITCH
Reverse Light
Rear Window Defrost
*Engine Control Module Located Behind Center Console. BLACK / YELLOW Cold Start Wire Needs To Be Powered Up In The Start Mode.
Immobilizer Bypass
MO
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
