wiring for 1999 olds Aurora
alik
Member - Posts: 10
Posted: February 01, 2005 at 3:13 PM / IP Logged
Need wiring diagram for '99 Aurora OR any other help ...Had remote start/ alarm  installed but suspecting some wires are incorrectly hooked up. The parking lights kept  flashing even when car is off and armed, when shock sensor activated and alarm goes of  the doors unlock for some reason.
 Had the headlight (control) module changed, after it seemed to cause problems, the flashing stopped but i'm suspecting more wiring problems.
boomer_106
Silver - Posts: 710
Posted: February 03, 2005 at 10:34 PM / IP Logged
Oldsmobile
Aurora
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
PURPLE / WHITE
Ignition  #3:
WHITE
Accessory:
ORAN
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT IGNITION CONTROL MODULE *
Parking Lights:
BROWN (+)
AT LAMP CONTROL MODULE
Headlights:
WHITE (-)
AT HEADLIGHT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Control Module Located On Passenger Front Of Engine (3.8L), Or On Top Rear Of Engine (V-8). ** This Vehicle Is Equipped With GM's VATS Anti-Theft System ; See Note #237.
Oldsmobile
Aurora
1996-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
OEM Alarm Disarm:
L GREEN (-)
DRIVER'S KICK PANEL
Dome  Lights/Superv:
WHITE (-)
AT COURTESY LIGHT ***
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
RED / BLACK
DRIVER'S KICK PANEL ****
Power  Unlock:
ORANGE / BLACK
Trunk  Release:
BLACK (+)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
WHITE (-)
Notes:
** WHITE (-) Wire Also Located At Multi Function Alarm, Lock & Lighting (MALL) Module In Driver Kick Panel. Optional Door Trigger BLACK (-) (Front Doors) & D BLUE (-) (Rear Doors) At MALL Module. Diode Isolation Needed, Cathode (*Band) Side Of Diode Faces OEM Wires. *** See Note #202 - Positive Door Lock Diagram.
