2005 Toyota 4runner SE alarm w/r start
DevineT4R
Posted: February 03, 2005 at 1:38 AM / IP Logged
I need a 2005 Toyota 4Runner Wiring diagram to install a Compustar Alarm w/ remote start.
jandjav
Member - Posts: 13
Posted: February 05, 2005 at 12:47 AM / IP Logged
PRINTABLE VERSION
TOYOTA
MODEL YEAR(S)
4-RUNNER 2005 -
KEY T-HARNESS IMMOBILIZER
N/A N/A 791 BYPASS MODULE and EXTRA IGNITION KEY
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT WHITE/ BLUE and RED (+) IGNITION SWITCH HARNESS
STARTERGREEN/ BLACK (+) IGNITION SWITCH HARNESS
STARTER 2N/A
IGNITION 1BLACK/ RED (+)IGNITION SWITCH HARNESS
IGNITION 2BLUE / YELLOW (+)IGNITION SWITCH HARNESS
IGNITION 3N/A
ACCESSORY /HEATER BLOWER 1WHITE/ GREEN (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEGREEN/ YELLOW (-) IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )GREEN (-) @ BECU, TOP PLUG PIN 8 See NOTE *1
PARKING LIGHTS ( + )GREEN (+) LEFT of FUSES, 16-PIN Plug
POWER LOCKBLUE IN DRIVERS KICK PANEL, 18-PIN Plug (TYPE B)
POWER UNLOCKGREEN (DOUBLE PULSE) IN DRIVERS KICK PANEL, 18-PIN Plug (TYPE B)
DOOR TRIGGERPURPLE / YELLOW (-) @ BECU, TOP Plug, PIN 12 See NOTE *1
DOMELIGHT SUPERVISIONWHITE (-) @ Plug to the RIGHT of the FUSES, Pin 8
TRUNK RELEASEN/A
SLIDING POWER DOORN/A
HORNGREEN/ RED (-) @ HORN SWITCH
TACHBLACK/ WHITE @ ECM BEHIND GLOVEBOX See NOTE *2
WAIT TO START LIGHTN/A
BRAKEGREEN/ YELLOW (+) LEFT of FUSES, 16-Pin Plug
FACTORY ALARM DISARM DISARMS with KEYSENSE wire
ANTI-THEFTTRANSPONDER @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE *1 the BECU is part of the FUSE/RELAY BOX under the DRIVERS SIDE of the DASH. the unit has 3 Plugs on the RIGHT SIDE of the FUSE BOX, these are the BECU harnesses. NOTE *2 on 6 Cylinder vehicles, it is the second plug from the bottom, Pin 1, or at the DATA LINK Connector under the drivers side of the dash,and on the V-8, it is in the bottom plug, Pin 5.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
