Wiring diagram 2003 Toyota Matrix
craftsmann
Posted: April 28, 2002 at 6:21 PM / IP Logged
Anybody having wiring diagram for 2003  Toyota Matrix. I am installing power door locks on it. I cheaped out on the option.Thanks
the12volt
Administrator - Posts: 3,959
Posted: April 28, 2002 at 6:33 PM / IP Logged
Hi craftsmann, I don't have any info for a 2003 Matrix, but If you're only adding power locks, besides wiring the actuators to the switches, all you'll need to connect to in the vehicle is a constant 12V+ source (battery positive) and ground (vehicle chassis).
the12volt
Platinum - Posts: 12,488
Posted: April 28, 2002 at 6:49 PM / IP Logged
What do you need as far as colors go ? If you are adding door lock actuators all you will need is power and ground with the switch you are installing. Are you installing a remote keyless entry as well ?
craftsmann
Posted: April 29, 2002 at 6:10 AM / IP Logged
Jeff thanks for the advise. I am also adding keyless entry with the power locks.
Posted: April 29, 2002 at 6:04 PM / IP Logged
All you will need is the constant, a ground and the two wires coming off the door lock actuators. If the keyless entry module require more than just these connections you can you can use your DMM to figure out the wires.
scss
Member - Posts: 25
Posted: May 01, 2002 at 12:42 AM / IP Logged
I e-mailed you the wire diagram. good luck
Jando
Security Specialist
If its a Ford Dont do it
oswaldo
Posted: November 23, 2002 at 5:56 AM / IP Logged
Wiring diagram 2003 Toyota Matrix -- posted image.Jando can I get a copy of that Matrix diagram too?
Oz
acucci
Posted: December 22, 2002 at 1:26 PM / IP Logged
Jando can I get a copy of that 2003 Matrix diagram too? I just bought my wife a new matrix for Christmas. If I may, I also have a 2001 Toyota Prius and would like a wiring diagram for this also. I would like to outfit both with an alarm system.
Tony
A PROFESSIONAL is one who does one's Best Work even if one does not want to or feel up to doing one's Best!
1fastgtp
Posted: January 05, 2003 at 2:30 PM / IP Logged
Jando I was trying to install a couple relays to make the the Factory RS3200+ beep for lock and unlock. The info somebody provided me did not match, i took the driver kick panel apart, the passenger kick panel apart and the colors did not match, i only found one of the four wire i was supposted to use and it wasn't the color i was told.
Can you help me ?
Thanks in advance
Oz
