2005 Toyota Corolla wiring Alarm & Astart
superman1218
Member - Posts: 13
Posted: February 28, 2005 at 12:35 AM / IP Logged
Anyone got a wiring diagramfor the new 2005 Toyota Corolla CE... I need to install an alarm and auto start.. Thanks in advance.
superman
boomer_106
Silver - Posts: 710
Posted: February 28, 2005 at 12:50 AM / IP Logged
Try this.
Toyota
Corolla
2004-2005
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK ac
AT IGNITION COILS*
Parking Lights:
GREEN (+)
DRIVERS KICK, HARNESS LEADING TO REAR
Headlights:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 On the 2005 models, this vehicle is equipted with a transponder theft system. Must bypass. We recommend the use of our universal alarm bypass module # 20402
Toyota
Corolla
2004-2005
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE OR BLACK
OEM Alarm Disarm:
BLUE/BLACK (keysense wire)
IGNITION SWITCH HARNESS ( - )
Dome  Lights/Superv:
RED / WHITE (-)
AT INSTRUMENT CLUSTER OR AT FUSE BOX *
OEM Horn:
GREEN/ YELLOW
STEERING COLUMN HARNESS
Power  Lock:
GREEN ( - )
DRIVERS KICK 10 PIN PLUG
Power  Unlock:
BLUE / YELLOW (double pulse) ( - )
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
Notes:
* There Are Mulitple RED / White Wires Near The Fuse Box. Some Will Work Individual Doors Only. Test With A Meter To Identify The Single Wire That Reacts To All Doors. For Dome Light Supervision, Use One Of The Individual Doors.
superman1218
Member - Posts: 13
Posted: February 28, 2005 at 12:55 AM / IP Logged
Boomer Thanks man..
superman
boomer_106
Silver - Posts: 710
Posted: February 28, 2005 at 12:56 AM / IP Logged
You're Welcome bud.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
