1994 voyager wiring diagram help
groundnpound
Posted: March 05, 2005 at 8:48 PM / IP Logged
I have a 1994 Voyager and the main fuse box under the dash on driver side had a fuse completly blown and burnt a whole through the fuse box. (it was like this when I bought it)
I went to the stock yard and got one from a junked car (same model and engine size) I replaced the wires 1 at a time so not to get any crossed but in the end had 1 extra wire with a fuse box connector and 1 wire that had been cut at some time in the past.
Bottom line I need a wiring diagram for the fuse box, I bought a chiltons and haynes manual but its not listed 1994 voyager wiring diagram help -- posted image.
Can someone please help I need to go out of town in 6 days and dont want to take a bus lol
thepencil
Gold - Posts: 1,526
Posted: March 05, 2005 at 9:42 PM / IP Logged
The bus is not a bad option if this doesn't help you out.   Look at it this way, you are leaving the driving to the professional so that you can do more sight seeing.   :)
1994 Chrysler Town and Country
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red & pink/black    |+ |ignition harness            |
|          STARTER|yellow              |+ |ignition harness            |
|        IGNITION|dk. blue            |+ |ignition harness            |
|        ACCESSORY|BLACK/ orange        |+ |ignition harness            |
|       POWER LOCK|ORANGE / white        |+ |relays in center console    |
|     POWER UNLOCK|pink/purple        |+ |relays in center console    |
|       LOCK MOTOR|ORANGE / black        |   |keyless entry module *1     |
|     UNLOCK MOTOR|dk. blue            |   |keyless entry module *1     |
|    DISARM DEFEAT|pink/purple        |   |keyless entry module *1     |
| PARKING LIGHTS +|BLACK / YELLOW        |   |low in drivers kick        |
| PARKING LIGHTS -|BROWN / orange        |   |headlight switch            |
|       HEADLIGHTS|ORANGE / white        |- |headlight switch            |
|     DOOR TRIGGER|yellow              |- |center console *2           |
| DOME SUPERVISION|use door trigger    |   |                            |
| TRUNK/HATCH PIN|tied in with doors |   |                            |
|TRNK/HTCH RELEASE|GREEN/ black        |+ |at switch                   |
|       TACHOMETER|blk/gry,red,blu/yel |   |coil pack *3               |
|       BRAKE WIRE|WHITE/ tan           |+ |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |- |steering column             |
|           WIPERS|RED / yellow          |+ |steering column             |
| LF WINDOW UP/DN|lt. blue - white    |A |drivers door switch        |
| RF WINDOW UP/DN|brn/wht - pur/wht   |A |drivers door or kick        |
| LR WINDOW UP/DN|lt. blue - white    |A |LR window switch            |
| RR WINDOW UP/DN|brn/wht - pur/wht   |A |RR window switch            |
Notes:
*1 The keyless entry module is located under the top of the dash panel in the center of the dash.    *2 Look for the silver module bolted to the floor close to the door lock relays behind the center console. *3 The 3.3L V6 engine uses a triple coil pack. Wire colors are for 2 cylinders each. For 3.0L V6 and 2.5L 4 cyl engines use gray at the coil.
Be careful whose advice you buy, but be patient with those who supply it.1994 voyager wiring diagram help -- posted image.
groundnpound
Posted: March 05, 2005 at 10:09 PM / IP Logged
Thanks for the quick reply. Could you explain how to use this?
If Im looking at the actual fuse box how do I know what wires plug into what hole. I have a picture Ill post, maybe that will help. I need to know what wires plug into what slots on the back of this fuse box
thepencil
Gold - Posts: 1,526
Posted: March 06, 2005 at 1:04 AM / IP Logged
Sorry groundnpound, that is as far as I can lead you. Someone else has to lead you from this point on.
groundnpound
Posted: March 06, 2005 at 9:56 AM / IP Logged
Thanks thepencil if thats the color chatr for the fuse box then I am closer then I was LOL
I just need someone to talk down to me so I understand how to use it :P
Im sure someone here has exactly what I need or the info to set me straight.
PS I HATE BUS RIDES
