2002 Maxda Protege 5, Alarm Wiring
boostedsol
Posted: November 07, 2002 at 10:00 PM / IP Logged
Does anyone know if the wiring for the protege 5 and the sedan is the same?
I have the wiring colors for the sedan but need it for the protege 5... Any ideas?
Thanks in advance.
Platinum - Posts: 12,488
Posted: November 08, 2002 at 1:03 AM / IP Logged
This is the wireing for the Protege 5:
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|BLACK/ white, black  |+  |ignition harness            |
|          STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|BLACK/ white         |+  |ignition harness            |
|       POWER LOCK|lt GREEN/ red *1     |-  |module high in driver kick  |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|red                 |   |door lock relays *2         |
|     UNLOCK MOTOR|blue                |   |door lock relays *2         |
|    DISARM DEFEAT|RED / black           |   |door lock relays *2         |
| PARKING LIGHTS +|lt GREEN/ black      |   |drivers kick panel          |
| PARKING LIGHTS -|brown               |   |headlight switch            |
|       HEADLIGHTS|RED / yellow          |-  |headlight switch            |
|     DOOR TRIGGER|BLACK/ blue          |-  |drivers kick panel          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / green           |-  |at light in trunk           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|PURPLE / white        |   |diagnostic connector *3     |
|      SPEED SENSE|orange or grn/red   |   |pin 58 of ECM *4            |
|       BRAKE WIRE|GREEN/  YELLOW        |+  |brake switch                |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|blu/wht(L),blu/red(H|+  |steering column             |
|  LF WINDOW UP/DN|RED / blk - yel/grn   |A  |drivers door switch         |
|  RF WINDOW UP/DN|grn/wht - lt grn/blk|A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|RED / grn - yel/red   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|blu/wht - grn/red   |A  |drivers switch or kick panel|
Notes:
*1 This is a one wire system, must use relays. Lock requires negative trigger through a 1.5K resistor, Unlock requires a negative trigger to the same wire.  *2 The door lock relays are located to the drivers side of the brake pedal.    *3 The diagnostic connector is in driver side rear corner of the engine compartment. Can also find tach in pin 48 of the ECM.  *4 The ECM is behind the passenger side of the dash.
boostedsol
Posted: November 08, 2002 at 11:40 AM / IP Logged
thanks Velocity Motors2002 Maxda Protege 5, Alarm Wiring -- posted image.
Posted: November 08, 2002 at 12:20 PM / IP Logged
No problemo
jmcdonald
Posted: January 16, 2003 at 3:42 PM / IP Logged
jeff, you say the Speed Sensor is pin 58 on the ecm and the
tach is pin 48 of the ecm.  Can you tell me what the numbering sequence
of the ecu is, ie how do I find pin 58?  I am installing a rostra
cruise control soon in my Protege5 (Astina SP20).
Also I am curious whether the ecm you have in the american/canadian protege is
the same as we have in the protege in australia, your protege5 is the
same as our astina sp20, well, in appearance and engine specs at least.
Do you know the model number of the ecm in the protege5?
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
