Switched +12V in a 04 Envoy?
ceeceebee
Posted: April 01, 2005 at 8:12 AM / IP Logged
Hello,
I am looking for a source of switched +12V behind the dash on a 04 GMC Envoy. I am adding a integrated Bluetooth Handsfree carkit. From what I can tell, it does not come to the factory radio, which I assume uses the data bus to control on/off via the ignition. Any ideas?
Thanks in advance,
Clay
Bmnicolosi
Copper - Posts: 173
Posted: April 01, 2005 at 10:21 AM / IP Logged
run a wire down to the ignition harness and grab the pink for ignition or the orange for accessory
If you say "I already know how", don't ask me a single question.
ceeceebee
Posted: April 01, 2005 at 10:37 AM / IP Logged
Bmnicolosi,
Thanks for the rely! I'll try that; I saw the wire marked 'ignition' in the harness (in a related post) and thought about giving it a try, but was not sure if that was +12 only when cranking, or if it was energized anytime the key was 'on'. From your comments, I'll take it is the latter and will proceed as such. Thanks again!
Clay
ceeceebee
Posted: April 01, 2005 at 10:46 AM / IP Logged
One other question:
According to the ingition harness diagram, the 'accessory' wire is orange. In all other places in the harness, orange is constant +12V from the battery. Is this true here as well?
Clay
ceeceebee
Posted: April 01, 2005 at 12:02 PM / IP Logged
I tapped into the Pink ingition wire; worked like a charm. thanks.
Clay
