1996 honda civic alarm
cisco
Posted: November 10, 2002 at 11:42 AM / IP Logged
does anyone have a wiring diagrahm for a 1996-1998 honda civic?
Platinum - Posts: 12,488
Posted: November 10, 2002 at 11:50 AM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|GREEN / WHITE         |-  |blue plug dkp or *2         |
|     POWER UNLOCK|GREEN/ orange*3      |-  |blue plug dkp or *2         |
| PARKING LIGHTS +|RED / black           |   |dkp/fuse box or *4          |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / wht(L)RED / blu(H)|+  |steering column             |
|     DOOR TRIGGER|lt. GREEN/ red*5     |-  |factory alarm plug*2        |
|  TRUNK/HATCH PIN|blue/blk*6          |-  |dkp, harness to rear        |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|blue                |   |test connector*1            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|gray or blue        |-  |column or*2                 |
|           WIPERS|blue and blue / YELLOW|-  |steering column             |
|  LF WINDOW UP/DN|RED / yellow - RED / blu|A  |drivers door                |
|  RF WINDOW UP/DN|blue/yel - blue/org |A  |drivers kick panel          |
|  LR WINDOW UP/DN|grn/yel - green     |A  |dkp, harness to rear        |
|  RR WINDOW UP/DN|yellow - yellow/grn |A  |dkp, harness to rear        |
Notes:
*1 Drivers side fire wall under hood.  *2 Factory alarm plug located behind radio. (GREEN/ plug).  *3 Can also use blue / YELLOW for driver door unlock only.  *4 Male blade terminal at fuse box. Also at the back of the dimmer switch.  *5 Can also be found in a light green plug above the fuse box or bottom of drivers kick, harness to rear. For dome supervision use lt. GREEN/ black at factory alarm/keyless plug.  *6 Also available at factory alarm plug. (lt. green).
toddbenson
Posted: November 16, 2002 at 1:22 AM / IP Logged
Hey Jeff i put a stereo in a 96 civic. where does the green plug go? cause now my factory door locks wont activate though the remote and the dome light wont work. anything would help. thanks
Posted: November 16, 2002 at 4:51 PM / IP Logged
Did you use a wiring harness or did you cut off the plug at the radio ? Here is a link to a CD installation of the deck: http://www.installdr.com/InstallDocs/Honda/PDF/466013.pdf
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
