2000 Dodge Avenger ES
Powerslave0
Copper - Posts: 116
Posted: November 12, 2002 at 6:59 AM / IP Logged
Check out http://cloud.prohosting.com/davenger for your guide to your Dodge avenger.  Information on the Six and Four cylinder, from production to discontinued.  Ask any questions here as well.
Powerslave0
Copper - Posts: 116
Posted: November 12, 2002 at 7:07 AM / IP Logged
Place to run wire?
On the passenger side, along the floor by the door, there is a plastic channel to run wires through.  You have to pull the step guard off, and pull the carpet clips back.  It should be empty from the factory.  I ran CD changer and power lines here, along with RCA cables.
There is also one on the Driver side, but it is pretty well used up.  You may fit one or two power lines in there.
It is wise to run power on one side, and your audio lines on another side.  You can do that with the Avenger in these locations.
