95 Nissan Quest Stereo Wiring
kenya_guy
Posted: June 06, 2005 at 7:40 AM / IP Logged
Hey all:
New here but having some serious trouble trying to throw a new deck in my 95 quest. need a wiring diagram very badly. any help would be appreciated,
thanks again
Eric
thepencil
Gold - Posts: 1,526
Posted: June 06, 2005 at 8:13 AM / IP Logged
You should get yourself a wiring harness, but check the wiring diagram here to see if this will help you out.
Be careful whose advice you buy, but be patient with those who supply it.95 Nissan Quest Stereo Wiring -- posted image.
kenya_guy
Posted: June 07, 2005 at 6:27 AM / IP Logged
thanks a bunch
where would I buy this wiring harness?
thanks again
Eric
thepencil
Gold - Posts: 1,526
Posted: June 07, 2005 at 9:09 AM / IP Logged
Any stereo shop. Future Shop, Best BUY. Where are you located? If you are close to me you can get one from me.
kenya_guy
Posted: June 07, 2005 at 9:13 AM / IP Logged
located in PEI which was my big problem but I found one I think at canadian tire, so I should be ok
thanks anyway though
Eric
kenya_guy
Posted: June 07, 2005 at 9:26 AM / IP Logged
hate to be a bother here but are all wiring harness' for a nissan going to be the same as long as I get it for the right year?.
I've got to assume so but don't want to make the trip to buy the harness and then it's not right
thanks again
thepencil
Gold - Posts: 1,526
Posted: June 08, 2005 at 9:47 AM / IP Logged
Not really, you may have a factory amp for your particular vehicle. If that is the case your harness will be different. Take the stereo unit out and take a look at the harness. That will probably be better than just guessing what's behind there. If can get take a picture of it I will be able to tell you which to get. Cdn Tire will not have a harness for a premium system ( build in factory amp). They have just the basic one, but a good stereo shop will have what you need.
kenya_guy
Posted: June 10, 2005 at 10:36 AM / IP Logged
yeah so it is the premium system I have need the strange amp integration harness, anyone know where I can get one in PEI, yeah I'll check around myself
thanks again
Eric
