2001 nissan xtterra
Welcome Guest :)
chasesaccessori
Copper -
Posted: November 22, 2002 at 2:49 PM / IP Logged
Alarm and stereo wireing if different.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
Tryder
Member -
Posted: November 22, 2002 at 4:11 PM / IP Logged
Wire Function | Wire Color | Wire Location |
Constant 12 volts | Green | Ignition switch harness |
Ignition 12 volts | BLACK/ white | Ignition switch harness |
Starter Kill | BLACK / YELLOW | Ignition switch harness |
Dome Light | RED / black(-) | At Pin Switch |
Trunk Pin Switch | Same as above | Same as above |
Parking Lamp | Blue/Red | (+) Behind Light Switch |
Power Lock | Light GREEN/ Red (At smart Entrance) | SMART ENTRANCE CONTROL UNIT Is Located High In The Driver's Kick Panel. |
Power unlock | Brown | Driver side Kick Panel |
ACCESORIES | Wire Color | Wire Location |
Window UpWindowsType: Reverse Polarity, Positive, Normally Grounded | Drivers side: BluePassenger: blue YellowDrivers Rear: Green RedPassenger Rear: green white | @ main Switch (drivers side door) |
Window Down | Driver Front: blue/blackPassenger Front: blue/whiteDriv Rear: GREEN/ YELLOWPass Rear: GREEN/ black | @ main Switch (drivers side door) |
Ignition Key Warning | WHITE/ Green (+) | Steering column Harness |
Trunk Release | NA | NA |
OEM Horn | Brown (-) | Steering Column HarnessW/ OEM Alarm LT GREEN/ RED (-) At Relay Or SECU. |
Head Lights | Red(+) DR,& RED / blue | (+)(PASS)must be relay isolated |
OEM Arm | Yellow(-) | At smart entrance control unit |
OEM Disarm | Yellow/red(-) | Same |
securinu
Silver -
Posted: November 24, 2002 at 8:55 PM / IP Logged
hey click delete on that post before i go dizzy
Sound Pressure
Silver -
Posted: November 24, 2002 at 10:34 PM / IP Logged
That was a buzz and a half.
Sound Pressure
Friday, September 5, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
