2002 Ford Taurus keyless entry wiring
wishywashy
Posted: June 19, 2005 at 4:54 PM / IP Logged
I would like to install an Audiovox AA-925 keyless entry system and was looking for wiring information. Thank you for any help
thepencil
Gold - Posts: 1,526
Posted: June 20, 2005 at 9:55 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / TAURUS / 2002 / Keyless Entry
12volts lt. GREEN/ purple    +   ignition harness
Starter RED / lt. blue    +   ignition harness
Ignition RED / lt. green    +   ignition harness
Power Lock pink / YELLOW    -   26 pin plug at GEM
Notes: The GEM module is to the left of the steering column.
Power Unlock pink/ lt. green    -   26 pin plug at GEM
Lock Motor pink/black      top plug of fusebox
Unlock Motor RED / white      top plug of fusebox
Parking Lights+ brown      headlight switch or fusebox
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger BLACK/ orange    -   20 pin plug at GEM
Notes: This wire controls the door ajar indicator on the dash, must cut the wire and diode isolate it from the instrument cluster. Can also use individual negative door trigger wires in the 26 pin plug at the GEM. They are: yellow/black (LF), gray/red (RF), lt. GREEN/ YELLOW (LR), and pink/lt blue (RR).
Dome Supervision BLACK/ lt. blue    +   top plug of fusebox
Trunk/Hatch Release
Notes: With keyless entry it is purple / YELLOW (-) at the switch. Without keyless entry it is gray/red (+) at the switch. On the wagon, to unlock just the rear hatch use yellow/lt. green (-) in the 26 pin plug at the GEM.
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm pink/white    -   26 pin plug at GEM
Disarm No Unlock
Horn Trigger purple or blue    -   steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
SecuriLock
Part #: 556SW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2002 Ford Taurus keyless entry wiring -- posted image.
wishywashy
Posted: June 20, 2005 at 1:20 PM / IP Logged
Thank you so much for your help. It is greatly appreciated.
thepencil
Gold - Posts: 1,526
Posted: June 20, 2005 at 2:21 PM / IP Logged
You are most welcome.
