2005 Chevrolet Silverado Speaker Removal, Wiring
aareedy
Posted: June 20, 2005 at 10:33 PM / IP Logged
I need instructs on how to remove front & rear door panels to replace OEM speakers.  Also, anyone have a wiring diagram (or, know which column wire supplies 12V when key is on, or in accessory) ?
thepencil
Gold - Posts: 1,526
Posted: June 27, 2005 at 8:56 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SILVERADO / 2005 / Audio
Radio 12v orange   +   radio harness
Radio Ground BLACK/ white   -   radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination N/A
Factory Amp Turn-on pink   +   radio harness
Power Antenna N/A
LF Speaker +/- tan - gray   +,- radio harness
Notes: If equipped, the amplifier is under the center console.
RF Speaker +/- lt. green - dk. green   +,- radio harness
LR Speaker +/- brown - yellow   +,- radio harness
RR Speaker +/- dk. blue - lt. blue   +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 555LW
Alternate Part1 #: 555T
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and RED / white (not used).
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 456G
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2005 Chevrolet Silverado Speaker Removal, Wiring -- posted image.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
