05 Dodge Neon Alarm/Start Wiring
visionsss
Member - Posts: 19
Posted: July 07, 2005 at 9:23 PM / IP Logged
Can someone please help me with the wiring information for an 05 Dodge Neon. I would like to do a remote start alarm.
Fred Kincaid
Visions Sound & Security
GPS Northwest
thepencil
Gold - Posts: 1,526
Posted: July 07, 2005 at 10:11 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / NEON / 2005 / Remote Start
12volts pink/black (40A), red (30A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition dk. blue   +   ignition harness
Second Ignition RED / wht (with Autostick only)   +   ignition harness
Third Ignition N/A
Accessory BLACK/ orange   +   ignition harness
Second Accessory BLACK/ white   +   ignition harness
Keysense lt. blue   -   ignition harness
Power Lock lt. green   -   driver kick, door harness
Notes: Lock is negative trigger thru a 1K (1000) ohm resistor. Unlock is negative trigger thru a 250 ohm resistor. MUST use relays.
If the vehicle has factory alarm, arm/lock is negative trigger thru a 2.7K (2700) ohm resistor, and disarm/unlock is negative trigger thru a 7.5K (7500) ohm resistor, use double pulse for unlock.
Also found at the Remote Keyless Entry Module in the top center of the dash. Remove the dash top to access.
Can also use Directed 457C or 456L interface modules.
Power Unlock same as power lock wire
Lock Motor ORANGE / black   5wi driver kick, door harness
Notes: Also found at the Remote Keyless Entry Module in the top center of the dash. Remove the dash top to access.
Unlock Motor pink/black   5wi driver kick, door harness
Parking Lights+ BLACK / YELLOW   +   headlight switch
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt. green (F), dk. grn/red (R) +   turn signal switch
Turn Signal(R) tan (F), BROWN / red (R)   +   turn signal switch
Reverse Light PURPLE / black   +   driver kick, harness to rear
Door Trigger tan/blk (D), lt. blue/org (P)   -   dr kick, door harn and harn to rear
Notes: Use both wires and diode isolate each.
Dome Supervision yellow   -   driver kick, harness to rear
Trunk/Hatch Pin tan/black   -   trunk pin switch or light in trunk
Hood Pin BROWN / tan (export model only)   -   hood pin switch under hood
Trunk/Hatch Release BROWN / lt. blue   -   release switch in glovebox
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT dk. GREEN/ orange   ac   ignition coil or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan   +   brake pedal switch
Parking Brake WHITE/ black   -   parking brake switch
Horn Trigger BLACK/ red   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 457CW
Alternate Part1 #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.05 Dodge Neon Alarm/Start  Wiring -- posted image.
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
