2005 Nissan Maxima Alarm/Remote Start Wiring
ratmkicksass
Member - Posts: 14
Posted: July 13, 2005 at 10:48 PM / IP Logged
i am trying to install a remote starter on a 2005 nissan maxima, but need the wiring diagram. If anybody out there has it, please post
chungo
Copper - Posts: 135
Posted: July 13, 2005 at 11:35 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - NISSAN / MAXIMA / 2005 / Remote Start
[PRINT THIS PAGE]
12volts green (40A)  +  ignition harness
Starter BLACK/ red  +  ignition harness
Second Starter BLACK / YELLOW  +  ignition harness
Ignition BLACK/ red  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory red  +  ignition harness
Second Accessory WHITE/ blue  +  ignition harness
Keysense BLACK/ red  +  ignition harness or BCM, pin 37
Notes: The BCM (Body Control Module) is between the steering column and the fuse box.
Power Lock blue or pink/blue  -  driver door module in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock red (double pulse)  -  driver door module in door
Lock Motor gray  5wi BCM, pin 50
Unlock Motor green  5wi BCM, pin 44
Parking Lights+ RED / blue  +  driver kick, harness to rear
Parking Lights- N/A
Hazards GREEN/ red  -  BCM, pin 29
Turn Signal(L) GREEN/ black  +  BCM, pin 45
Turn Signal(R) GREEN/ YELLOW  +  BCM, pin 46
Reverse Light GREEN / WHITE  +  driver kick, harness to rear
Door Trigger see notes  -  BCM
Notes: The LF door is lt. blue in pin 62, the RF door is BROWN / white in pin 12, the LR door is RED / black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
Dome Supervision red  -  BCM, pin 48
Trunk/Hatch Pin PURPLE / white  -  BCM, pin 57
Hood Pin N/A
Trunk/Hatch Release blue or blue/white  -  BCM, pin 30
The fuel door release is green in the driver kick, in the harness to the rear. It is a high current negative wire.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT red or black  ac  any ignition coil or fuel injector
Wait to start N/A
Brake Wire RED / green  +  brake pedal switch
Parking Brake pink/black  -  parking brake switch
Horn Trigger GREEN / WHITE  -  horn switch
Memory Seat 1 blue/white  -  ADP Control Unit, pin 9
Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in the dash.
Memory Seat 2 purple  -  ADP Control Unit, pin 25
Memory Seat 3 N/A  -
2005 Nissan Maxima Alarm/Remote Start Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Notes: Standard on all models.
Saturday, October 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
