2001 Nissan Pathfinder Stereo Wiring Diagram
john422
Member - Posts: 9
Posted: August 03, 2005 at 2:10 PM / IP Logged
Does anyone have/know about a 2001 Nissan Pathfinder Wiring Diagram for installing a new head unit.  I need to know what the colored wires correspond to.  Thanks for the help.
john422
Member - Posts: 9
Posted: August 03, 2005 at 6:36 PM / IP Logged
is there anyone that can give me this information??? i could really use the help.  thank you.
Platinum - Posts: 12,488
Posted: August 03, 2005 at 10:49 PM / IP Logged
Go to Wal-Mart and get a harness for $ 3.99 otherwise if your dealing with a chopped installation from a previous owner, you can try the 2001 Nissan Pathfinder Stereo Wiring Diagram -- posted image.Search button
john422
Member - Posts: 9
Posted: August 04, 2005 at 8:41 AM / IP Logged
Jeff,
I won't be able to get a harness from Wal-Mart because the wires are exposed and I'm dealing with a chopped installation as you said.  I'll continue to search but if anyone knows the specifics for a 2001 Nissan Pathfinder, I could use really use the help.  Thanks.
john422
Member - Posts: 9
Posted: August 04, 2005 at 8:51 AM / IP Logged
the search didn't turn up any useful results for audio wiring diagrams.  if somebody knows this info please let me know, thanks.
john.
thepencil
Gold - Posts: 1,526
Posted: August 04, 2005 at 9:36 AM / IP Logged
Get yourself a digital multimeter. Find the +12V constant, 12V remote, and ground. Connect them to the new head unit. For speaker wire get yourself a 9V toy battery and listen to poping noise. If you have a factory amp you need to power up the factory amp. Use the wiring diagram below to serve as a guide. Test your wire first before connecting them.
NISSAN
P o w e r
Memory (+12v Constant) Red
Ignition (+12v Switched) (varies) Brown or Green
Ground (-) Black (varies - most don't have one)
Illumination RED / White
Dimmer RED / Black
Power Antenna Green
S p e a k e r s
Right Front (+) Brown
Right Front (-) BROWN / White
Left Front (+) Black
Left Front (-) BLACK/ White
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
Be careful whose advice you buy, but be patient with those who supply it.2001 Nissan Pathfinder Stereo Wiring Diagram -- posted image.
