How to bypass Pathfinder immobilizer
Haitep
Posted: August 20, 2005 at 12:22 AM / IP Logged
I have a PKN2 used to bypass Nissan pathfinder without spare key.   Please help me with the wire color coding of the 2003 Nissan Pathfinder immobilizer so that I can intall the module.
Thank you
genehewett
Copper - Posts: 151
Posted: September 14, 2005 at 10:47 PM / IP Logged
mo12v
Posted: September 14, 2005 at 11:03 PM / IP Logged
Iwould rather use the OMEGA # IB-N2.....................
Constant 12 voltsWHITE/ VIOLETIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterBLACK / YELLOWIGNITION SWITCH HARNESS
Dome LightBLACK/ BLUE (-)DRIVERS KICK PANEL
Trunk Pin Switch
Parking LampPINK/BLUE (+)TO RIGHT OF STEERING COLUMN
Power LockYELLOWAT MODULE TO THE RIGHT
Power UnlockLIGHT GREENOF STEERING COLUMN
Negative Pulse Door Locks
Accessories
Window Up
Window Down
Ign Key WarnWHITE/ RED (+)IGNITION SWITCH HARNESS
Trunk ReleaseLT.GREEN/ REDAT TRUNK RELEASE SWITCH
OEM Horn
Headlights
OEM Alarm Arm
OEM Alarm Disarm
Oem Hood Trigger: YELLOW/BLACK (-) In Harness To The Left Of Steering Column.
Negative Pulse Trunk Release Circuit
Remote Start
Tach SignalWHITE/ GREENAT MODULE ABOVE GAS PEDAL
Ignition #2RED / YELLOWIGNITION SWITCH HARNESS
Ignition #3
AccessoryBLACK / YELLOWIGNITION SWITCH HARNESS
Neutral SafetyBLACK (-)AT GEAR SELECTOR SWITCH
Brake LightGREEN/ YELLOW (+)SWITCH ABOVE PEDAL
Reverse LightYELLOW (+)PASSENGER KICK PANEL
Rear Window Defrost
MO
Sunday, March 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
