alarm/remote starter wiring diagram audi a4
Welcome Guest :)
joe wingate
Member -
Posted: December 06, 2002 at 2:01 PM / IP Logged
i have an audi a4 manual transmission factory alarm and locks . any wiring information would be helpful. installing a directstart cs423. jw
jgate
Moderator -
Posted: December 06, 2002 at 3:06 PM / IP Logged
What year ???
joe wingate
Member -
Posted: December 07, 2002 at 11:36 AM / IP Logged
sorry, jeff the audi a4 is a1999.
jgate
Moderator -
Posted: December 07, 2002 at 11:42 AM / IP Logged
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red |+ |ignition harness || STARTER|RED / black |+ |ignition harness || SECOND STARTER|blue |+ |ignition harness || IGNITION|black |+ |ignition harness || ACCESSORY|yellow/black |+ |ignition harness || POWER LOCK|brn/gry or RED / brn |- |drivers kick or alarm *1 || POWER UNLOCK|gray/white *5 |- |drivers kick or alarm *1 || PARKING LIGHTS +|gry/blk & gry/red | |headlight switch || HEADLIGHTS|yellow or yel/red |+ |headlight switch || DOOR TRIGGER|brn/yel & brn/wht |- |*4 || DOME SUPERVISION|use door trigger | | || TRUNK/HATCH PIN|WHITE/ black |- |alarm module *1 || HOOD PIN|BROWN / yellow |- |at hood pin switch ||TRNK/HTCH RELEASE|yellow/red |+ |at switch || FCTRY ALARM ARM|arms with lock | | ||FCTRY ALRM DISARM|disarms with unlock | | || TACHOMETER|GREEN/ blue | |instrument cluster or *2 || SPEED SENSE|WHITE/ blue | |instrument cluster or *3 || BRAKE WIRE|RED / black |+ |at switch || HORN TRIGGER|BLACK / YELLOW |+ |horn relay || WIPERS|blk/grn(L),blk/pur(H|+ |steering column || LF WINDOW UP/DN|not recommended | | || RF WINDOW UP/DN|not recommended | | || LR WINDOW UP/DN|not recommended | | || RR WINDOW UP/DN|not recommended | | |Notes:
*1 Factory alarm is on the bottom passenger side of the trunk. *2 Tach is also found at the ECM on the driver side firewall. *3 VSS is also found at the cruise control module behind the glove box. *4 BROWN / yellow in the drivers kick panel gets the drivers door, BROWN / white in the passenger kick panel gets all the other doors. Use both wires and must diode isolate from each other. *5 Unlock requires double pulse.Jeff
joe wingate
Member -
Posted: December 07, 2002 at 11:50 AM / IP Logged
jeff, thanks alot , you have been a big help. have great holidays!!
jgate
Moderator -
Posted: December 07, 2002 at 1:10 PM / IP Logged
No problemo
Friday, January 9, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
