Wiring Diagram 98 Nissan Maxima
dolfingirl1331
Posted: November 16, 2005 at 11:54 AM / IP Logged
Hello, I need a wiring diagram for a 98 Nissan Maxima
boomer_106
Silver - Posts: 710
Posted: November 16, 2005 at 8:25 PM / IP Logged
Here ya go.
Nissan | | Maxima | | 1996 - 1999
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:BLACK/ GREEN & BLK/WHT
Ignition #1:BLACK/ REDIGNITION SWITCH HARNESS
Ignition #2:RED / YELLOWIGNITION SWITCH HARNESS
Ignition #3:N/A
Accessory:WHITE/ BLUEIGNITION SWITCH HARNESS
Brake Light:RED / GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:WHITE/ GREENAT ENGINE CONTROL MODULE *
Parking Lights:RED / GREEN (+)AT HEADLIGHT SWITCH
Headlights:GREEN/ YELLOW (DR) &BLUE/BLACK (PS) (+) AT HEADLIGHT SW.
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:* Engine Control Module Located Behind Center Console. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Connected to Remtoes Starter Wire In Order For Vehicle To Start When Engine Is Cold; See Note #235 - Nissan Starter Wires Diagram For Co
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:WHITE/ PURPLEIGNITION SWITCH HARNESS
OEM Alarm Disarm:GREEN/ YELLOW (-)IN DRIVER DOOR (DRIVER SWITCH)
OEM Horn:GREEN / WHITE (-)STEERING COLUMN HARNESS
Power Lock:LIGHT GREEN/ REDAT LOCAL CONTROL UNIT (DR. SWITCH)****
Power Unlock:GREEN/ YELLOWAT LOCAL CONTROL UNIT (DR. SWITCH)****
Trunk Release:PURPLE / YELLOW (-)AT TRUNK RELEASE SWITCH
Alarm Input Wire:RED / WHITE (-)AT BODY CONTROL MODULE ***
Notes:*** Body Control Module Located Behind Center Console Underneath A/T Control Module. RED / WHITE (-) Wire Also Found At Interior Fuse Panel. **** See Double Pulse Door Lock Diagram Note #231 , or program module for double pulse door locks.
