1997 dakota alarm
johnboy469
Posted: November 16, 2005 at 12:09 PM / IP Logged
i am about to install a alarm in my dodge but its been awhile since i have done an alarm. it has the crappy factory security system that locks the doors and the horn honks if the doors are opened from the inside. my question is how do i disarm that crap so i can install the real alarm. or do i even need to. someone let me know. thanks
boomer_106
Silver - Posts: 710
Posted: November 16, 2005 at 8:24 PM / IP Logged
Well here is the sheet for your vehicle. It has the  OEM alarm disarm wire.
Dodge | | Dakota | | 1997 - 1999
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:DK. BLUE / YELLOW
Ignition #1:D BLUEIGNITION SWITCH HARNESS
Ignition #2:BLACK/ ORANGEIGNITION SWITCH HARNESS (BLOWER)
Ignition #3:N/A
Accessory:BLACK/ WHITEIGNITION SWITCH HARNESS
Brake Light:WHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:BLACK/ GRAYAT IGNITION COIL OR PCM *
Parking Lights:BLACK / YELLOW (+)AT HEADLIGHT SWITCH **
Headlights:L GREEN (+)AT HEADLIGHT SWITCH (# - # ONLY)
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:* Powertrain Control Module (PCM) Located On Passenger Rear Of Engine.
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:PINK/BLACK & REDIGNITION SWITCH HARNESS
OEM Alarm Disarm:BLACK/ ORANGE (-)# PIN BLACK CONN. BEHIND DR. DASH
OEM Horn:BLACK/ RED (-)STEERING COLUMN HARNESS
Power Lock:ORANGE / VIOLET# PIN BLACK CONNECTOR BELOW
Power Unlock:PINK/VIOLETFUSE BOX BEHIND DRIVER DASH ***
Trunk Release:N/A
Alarm Input Wire:YELLOW (-)AT COURTESY LIGHT OR HEADLIGHT SWITCH
Notes:** BLACK / YELLOW (+) Wire Also Found In 74 Pin Connector Below Fuse Box Behind Driver Dash. *** See Note # 202 - Positive Pulse Door Lock Diagram For 1997 - 1998 Models, And Note # 203 - Reverse Polarity Door Lock Diagram For 1999 - 2000 Models.
