Wiring Diagram for 93 Toyota Camry
coolsalron
Posted: November 16, 2005 at 8:51 PM / IP Logged
can some post wiring Diagram for 93 Toyota Camry EXL 4DR  v6 J
i'm trying to install a Remote Start security & keyless entry system and is my first time trying to do this.The direction that came with Alarm are useless ,cuz i don't know where to start.
thepencil
Gold - Posts: 1,526
Posted: November 17, 2005 at 11:24 AM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white - WHITE/ red   |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|BLACK/ orange        |+ |ignition harness            |
|        ACCESSORY|pink/blue *1        |+ |ignition harness            |
|       POWER LOCK|blue/white          |- |passengers kick blue plug   |
|     POWER UNLOCK|lt. GREEN/ red       |- |passengers kick blue plug   |
| PARKING LIGHTS +|green               |   |bottom of fuse box *3       |
| PARKING LIGHTS -|green               |   |steering column             |
|       HEADLIGHTS|RED / yellow          |- |steering column             |
|     DOOR TRIGGER|RED / white           |- |*4                          |
| TRUNK/HATCH PIN|RED / white           |- |light or sw. in trunk       |
|        HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
| FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|black               |   |check connector *2          |
|       BRAKE WIRE|GREEN / WHITE        |+ |bottom of fuse box *3       |
|     HORN TRIGGER|GREEN/ black        |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|green - red        |A |drivers door switch        |
| RF WINDOW UP/DN|grn/wht - RED / blu   |A |drivers kick panel          |
| LR WINDOW UP/DN|grn/yel - RED / blk   |A |drivers kick panel          |
| RR WINDOW UP/DN|grn/blk - RED / blk   |A |drivers kick panel          |
Notes:
*1 Not required for remote start. *2 Located on the rear side of the passenger strut tower. *3 In a white connector just below the fuses with the wires exiting out toward you.    *4 Remove black plastic air duct covering the top right side of the fuse box to access a 6 pin plug containing the RED / white.
Be careful whose advice you buy, but be patient with those who supply it.Wiring Diagram for 93 Toyota Camry -- posted image.
