2006 sonata, remote start wiring
joefcormier
Posted: December 18, 2005 at 7:41 AM / IP Logged
need wiring colors for a remote starter
infinkc
Copper - Posts: 438
Posted: December 18, 2005 at 11:55 AM / IP Logged
WIRING INFORMATION - HYUNDAI / SONATA / 2006 / Remote Start
12volts pink (40A), red (30A)   +   ignition harness
Starter green   +   ignition harness
Second Starter N/A
Ignition blue   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory green   +   ignition harness
Keysense white   +   ign harn or BCM, wht 24P plug, pin 4
Notes: The BCM (Body Control Module) is under the center console, below the A/C controls.
Power Lock pink/black   -   DKP or BCM, wht 20 pin plug, pin 3
Power Unlock yellow/black   -   DKP or BCM, wht 20 pin plug, pin 11
Lock Motor gray   5wi driver kick, door harness
Unlock Motor red to white   5wi driver kick, door harness
Parking Lights+ BROWN / blk (L), GREEN/ blk (R)   +   driver kick, harness to rear
Parking Lights- pink   -   sw. or BCM, wht 20 pin plug, pin 4
Hazards brown   -   BCM, gray 24 pin plug, pin 9
Turn Signal(L) gray   +   turn signal switch
Turn Signal(R) green   +   turn signal switch
Reverse Light blue   +   driver kick, harness to rear
Door Trigger pink   -   BCM, wht 24 pin plug, pin 22
Dome Supervision yellow/black to yellow   -   BCM, gray 24 pin plug, pin 1
Trunk/Hatch Pin GREEN/ black   -   DKP or BCM, wht 24 pin plug, pin 23
Hood Pin green   -   pin sw. or BCM, wht 24P plug, pin 24
Trunk/Hatch Release white   -   DKP or BCM, wht 20 pin plug, pin 13
The trunk release motor wire is red (+) in the driver kick, harness to the rear.
The fuel lid release is GREEN/ black (+) in the driver kick, harness to the rear.
Power Sliding Door N/A
Factory Alarm Arm yellow   -   DKP or BCM, wht 20 pin plug, pin 1
Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm orange   -   DKP or BCM, wht 20 pin plug, pin 2
Disarm No Unlock see factory alarm disarm
Tachometer white or WHITE/ black   ac   instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is near the driver side shock tower under the hood. The tach wire is in pin 86 on the 2.4L, and in connector 1, pin 61 on the 3.3L.
For tach, can also go to any fuel injector and use the wire that is not black or orange.
Wait to start N/A
Brake Wire green   +   brake pedal switch
Parking Brake orange   -   parking brake switch
Horn Trigger white or yellow/orange   -   sw. or BCM, gray 24 pin plug, pin 8
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
There are 10 types of people in the world, ones that understand binary and ones that dont.
joefcormier
Posted: December 19, 2005 at 6:02 PM / IP Logged
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Yes Type:
Transponder
Part #: 556UW
thanks so much for your enfo your response was extremly quick
Tuesday, January 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
