Remote Start, 2001 Chevrolet Silverado
jrf123185
Posted: January 10, 2006 at 8:39 PM / IP Logged
I am installing a remote start on a 2001 Chevrolet Silverado. In the directions it says that the tach wire on the 4.8, 5.3, and 6.0L is the white wire that comes out of the red connector(top connector) on the ECU. Well this is not true for the 8.1L. Where exactly is it? And where does each wire go on the PLDATA II (passlock 2 bypass). Thanks.
Ryan
jaybird2020
Member - Posts: 16
Posted: January 16, 2006 at 12:48 AM / IP Logged
u should b able to get thetach behind the inst cluster
notoriouswill
Member - Posts: 32
Posted: February 01, 2006 at 10:58 PM / IP Logged
Tach is behind the cluster pin white wire. On later models it is pin A5 but not for sure if it is true with your year.
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
Remote Start, 2001 Chevrolet Silverado -- posted image.
notoriouswill
Member - Posts: 32
Posted: February 01, 2006 at 11:00 PM / IP Logged
Tach you should be able to get behind the cluster. I know on later models it is pin a5. Not for sure on your year though.
1 Memphis Mojo 15
autotek27
Member - Posts: 6
Posted: February 09, 2006 at 6:07 PM / IP Logged
Just did an 02 Silverado 8.1L..used the white wire at pin 10 in the red connector..that was the tach pick-up for this truck..as for the bypass..you have to get diagram from the bypass company..different bypass`s are wired in differently..I prefer the Bulldog 791 unit..its slick and learns quickly and the wiring diagram is with it.
b-(
tjdurham
Copper - Posts: 180
Posted: February 10, 2006 at 12:09 AM / IP Logged
you can go directly to an injector wire on the front of the motor they are wide open use the non pink wire in the 2 pin connector
tj
