1999.5 Infiniti QX4 Bose rear amp wiring
tykeeus
Posted: February 15, 2006 at 12:42 AM / IP Logged
I have a 1999.5 Infinti QX4 that has the factory Bose system. Someone chopped up the rear amp harness. What I need is the rear amp wiring diagram or plug color code. This should be the same as a Nissan Pathfinder. Any help would be appreciated.  Thanks!
tbass
Member - Posts: 7
Posted: February 18, 2006 at 10:15 AM / IP Logged
give the right car year, 95 or 99
The more you think the less you'll know. you betta ask somebody
tykeeus
Posted: February 18, 2006 at 11:20 PM / IP Logged
It is a 99 and a half or 1999.5 or 1999 1/2. They did some midyear changes. Basically an early version of the 2000. I would guess a 1999-2001 would be the same. I would sure like to get some help on this. Anyone out there with a 1999 or newer service manual? They usually have wiring diagrams. Thanks in advance.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
