Wiring Diagram 2005 GMC w3500 Diesel
iamdr7
Member - Posts: 12
Posted: April 02, 2006 at 7:32 PM / IP Logged
Need wiring diagram for this. Thanks
Moderator - Posts: 12,488
Posted: April 02, 2006 at 10:14 PM / IP Logged
You forgot to say please........
iamdr7
Member - Posts: 12
Posted: April 02, 2006 at 10:43 PM / IP Logged
Please
Posted: April 03, 2006 at 7:57 AM / IP Logged
12volts red (40A), red (40A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use Directed module 457GW
Notes: If Directed module 457GW is not available, refer to DirectFax document 1601.
On base model trucks, the 457GW is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock see power lock
Lock Motor gray  5wi driver door module in door
Unlock Motor tan  5wi driver door module in door
Parking Lights+ brown  +  driver kick panel
Parking Lights- gray/black  -  switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white  -  hazard switch
Turn Signal(L) dk. green  +  turn signal switch
Turn Signal(R) lt. green  +  turn signal switch
Reverse Light lt. green  +  BCM, black plug, pin F
Door Trigger gray/blk (L), BLACK/ wht (R)  -  each door module in each door
Notes: On base model trucks, the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5.
On 4dr trucks, the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM.
Use all wires and diode isolate.
Dome Supervision gray/black  +  BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the tach wire is in the green plug, pin 10.
On diesel models, the tach wire is in the gray plug, pin 37.
On hybrid models, the tach wire is in the green plug, pin 35.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start dk. blue  -  instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the blue plug, pin 26.
On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black  -  switch or BCM, gray plug, pin B9
Memory Seat 1 red  +  driver door module in door
Memory Seat 2 pink  +  driver door module in door
Memory Seat 3 N/A  +
Wiring Diagram 2005 GMC w3500 Diesel -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Not required if using the combo interface module. The Passlock II wire colors are yellow, black, and RED / white (not used).
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Notes:
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6402A
Posted: April 03, 2006 at 8:00 AM / IP Logged
Wiring Diagram 2005 GMC w3500 Diesel -- posted image.  2005 Chevy PU Wiring Diagram 2005 GMC w3500 Diesel -- posted image.
