2000 toyota mr2 alarm wiring?
andrewz24
Posted: April 07, 2006 at 5:14 PM / IP Logged
i need the security wiring for a 2000 toyota mr2 spyder. i need the lighting, power locks, ignition, and input trigger wire color and location
sir_misery
Member - Posts: 23
Posted: April 10, 2006 at 2:13 AM / IP Logged
- TOYOTA / MR2 / 2000 / Remote Start
12volts      wht/red & wht/blu       +       ignition harness
Starter      red       +       ignition harness
Second Starter
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition      RED / white       +       ignition harness
Third Ignition
Accessory      pink/blue       +       ignition harness
Second Accessory
Keysense
Power Lock      blue/white       -       drivers kick panel
Power Unlock      blue / YELLOW       -       drivers kick panel
Notes: Requires a double pulse for unlock. Using the same color wire in the passengers kick only requires a single pulse.
Lock Motor      blue/red             drivers kick panel
Unlock Motor      blue/black             drivers kick panel
Parking Lights+      green             drivers kick panel
Parking Lights-      RED / white             steering column
Door Trigger            -
Notes: Drivers door is red or RED / white in the drivers kick panel. Passenger door trigger is RED / white in the passenger kick panel. Use both wires and diode isolate each.
Dome Supervision      use door trigger
k
Tachometer      white             drivers running board
Brake Wire      GREEN / WHITE       +       at brake switch
Horn Trigger      WHITE/ red       -       steering column
yeh? i can do that?
see! told ya!
madrulez
Posted: April 10, 2006 at 3:44 AM / IP Logged
i bought a remote keyless entry systam and i have lose the installation manual and i cant inastall in my car..can anyone helpme?
shyne151
Posted: April 10, 2006 at 3:15 PM / IP Logged
I woudl say look on the manufactorer's website for a manual... most good companies like DEI have them available on their site.
madrulez
Posted: April 11, 2006 at 12:29 PM / IP Logged
it havent website:(
sir_misery
Member - Posts: 23
Posted: April 21, 2006 at 3:17 AM / IP Logged
did you look on the back of the brain sometimes they have the diagram on them
yeh? i can do that?
see! told ya!
sir_misery
Member - Posts: 23
Posted: April 21, 2006 at 3:18 AM / IP Logged
{TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" UNABLE="on"}{TR height="100%" UNABLE="on" width="100%"}{TD id=HB_Focus_Element vAlign=top width="100%" background=""0 UNABLE="off"}did you look on the back of the brain   sometimes the diagram is on them{/TD}{/TR}{TR UNABLE="on" hb_tag="1"}{TD style="FONT-SIZE: 1pt" height=1 UNABLE="on"}{DIV id=hotbar_promo}{/DIV}{/TD}{/TR}{/TABLE}{div style="width:240px;border-bottom:1px solid #eeeeee;margin-top:10px;margin-bottom:0px;"}{/div}{span style="font-size:.70em;line-height:1.2em;color:#000000;"}yeh? i can do that? {BR /} {BR /}see! told ya!{/span}
