01 Mustang GT Car Alarm Wiring
chrismiddleton
Member - Posts: 13
Posted: June 18, 2006 at 12:08 PM / IP Logged
Hi im trying to find the + Horn wire and the +/- door trigger wires so the alarm car sense when the doors are open. Could someone help me out and post these wires please.
auex
Platinum - Posts: 5,041
Posted: June 18, 2006 at 12:28 PM / IP Logged
+ horn is going to be under the hood, locate at the horn itself. Most alarms have - output so double check.
12volts yellow & lt. GREEN/ purple   +   ignition harness
Starter WHITE/ pink   +   ignition harness
Second Starter N/A
Ignition RED / lt. green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW and RED / black   +   ignition harness
Second Accessory BLACK/ lt. green   +   ignition harness
Keysense BLACK/ pink   -   ign harn, 26 pin plug, pin 9 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Lock lt. green   +   20 pin plug, pin 20 at GEM
Power Unlock purple   +   20 pin plug, pin 18 at GEM
Lock Motor RED / white   5wi 20 pin plug, pin 9 at GEM
Unlock Motor RED / orange   5wi 20 pin plug, pin 7 at GEM
Parking Lights+ brown   +   26 pin plug, pin 7 at GEM
Parking Lights- WHITE/ black   -   26 pin plug, pin 11 at GEM
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org(R)   +   steering column
Turn Signal(R) wht/lt blu(F), org/lt blu(R)   +   steering column
Reverse Light BLACK/ pink   +   26 pin plug, pin 20 at GEM
Door Trigger yel/black (L), gray/red (R)   -   20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ white   +   20 pin plug, pin 3 at GEM
Trunk/Hatch Pin BROWN / white   -   12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin N/A
Trunk/Hatch Release pink/lt. green   -   26 pin plug, pin 25 at GEM
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm dk. GREEN/ purple   -   20 pin plug, pin 16 at GEM
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or WHITE/ lt. blue   ac   ignition coil or coil pack
Wait to start N/A
Brake Wire RED / lt. green   +   brake pedal switch
Parking Brake purple / YELLOW or lt. blu/blk   -   12 pin plug, pin 4 at GEM
Horn Trigger yellow/lt. green   -   26 pin plug, pin 12 at GEM
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
