2003 Kia Sedona alarm wiring
gabalo
Posted: August 06, 2006 at 11:37 PM / IP Logged
Some one help me out with the factory wiring diagrams for a Alarm system installation include lock and windows.
spookiestylez
Silver - Posts: 531
Posted: August 07, 2006 at 2:57 AM / IP Logged
12voltsred & BLACK/ red + ignition harness
StarterBLACK / YELLOW to yellow + ignition harness
Second StarterN/A
IgnitionWHITE/ blue to white + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorygreen + ignition harness
Second Accessorywhite to blue + ignition harness
Keysense
Power LockWHITE/ black - plug left of steering column
Power UnlockRED / green - plug left of steering column
Lock Motorblue/red 5widriver kick, door harness
Unlock MotorRED / yellow to BLACK / YELLOW 5widriver kick, door harness
Parking Lights+RED / black + driver kick, harness to rear
Parking Lights-WHITE/ red or white - headlight switch
HazardsWHITE/ green - hazard switch
Turn Signal(L)white + steering column
Turn Signal(R)orange + steering column
Reverse LightRED / green + kick panel, harness to rear
Door TriggerWHITE/ red - top of fuse box
Notes: Also found green (-) behind the instrument cluster, in the left plug.
Dome Supervisionuse door trigger
Trunk/Hatch PinGREEN/ black - instrument cluster,left plug
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometeryellow/red ac instrument cluster,left plug
Notes: Can also use green at ignition coil under engine cover.
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brakeyellow/red - parking brake switch
Horn Triggeryellow/white - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
2003 Kia Sedona alarm wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
ACCESSORY
12volts
red & BLACK/ red
ignition harness
Headlightpink - headlight switch
Speed SenseWHITE/ black instrument cluster
Wipersblu/wht (L), grn/wht (H) + steering column
LF Window up/dnblue - white A driver window switch
RF Window up/dnRED / yellow - green A driver kick, door harness
LR Window up/dn
RR Window up/dn
Sun Roof open/closeGREEN/ YELLOW - GREEN/ red sun roof motor
Sun Roof Limit/close
Memory Seat 1
Memory Seat 2
Memory Seat 3
rtfm
gabalo
Posted: August 08, 2006 at 11:24 AM / IP Logged
Thank for your help.
spookiestylez
Silver - Posts: 531
Posted: August 12, 2006 at 11:27 PM / IP Logged
no problem, hope everything works out for ya
rtfm
