Lincoln amplified system wiring diagrams
music_man
Posted: September 16, 2006 at 1:39 AM / IP Logged
Hello people.
I am looking for a stereo wiring color code guide for a 1997 lincoln continental with the amplified system.
I am also looking for the same thing for a 1998 lincoln mark viii with amplified system.
In particular, I am seeking the small black connector (amplifier/speaker) plug wire color codes.
In the 97' continental, the plug wires are [blue/white stripe]; [gray]; [black]; [tan]; [GREEN/ black stripe]; [tan/orange stripe]; [BROWN / green stripe]; [WHITE/ pink stripe]; [blue/pink stripe]; [pink/blue stripe]
In the 98' mark viii, the plug wires are [GREEN/ black stripe]; [WHITE/ pink stripe]; [brown]; [PURPLE / white stripe]; [sky blue]; [black]; [green]; [WHITE/ orange stripe]; [sky blue/black stripe]; [yellow]
I assume that the black wires for both are the grounds, and the yellow for the 98' is the 12v power.  But the rest I haven't the slightest idea.  If anyone can provide me with information on which wires are for what with regard to these amplified systems, it would be greatly appreciated.
Thanks.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 17, 2006 at 2:22 PM / IP Logged
+12V DC Battery(Constant)Yellow Remote chassis unit 37 30 amp In-panel fuse panel
Switched AccessoryRED / lt.blue Remote chassis start. Front contr. unit: see notes. 29 10 amp In-panel fuse panel
Ground BLACK/ lt.green
Remote Turn On(output) Lt.GREEN/ black Remote chassis pin C468-8 for CD changer & pin C469-2 connected to front control unit pin C224-5.
Illumination BLACK/ white
Mute Dk.GREEN/ purple
Left Front + ORANGE / lt.green
Left Front - Lt.blue/white
Right Front + WHITE/ lt.green
Right Front - Dk.GREEN/ orange
Left Rear + Gray/lt.blue
Left Rear - Tan / YELLOW
Right Rear + ORANGE / red
Right Rear - BROWN / pink
Subwoofer + RED / black
Subwoofer - BROWN / orange
97 Continental
+12V DC Battery(Constant)RED / white  10 amp In-panel fuse panel
Switched AccessoryBLACK/ pink  10 amp In-panel fuse panel
Ground Black Also BLACK/ light green
Remote Turn On(output) Dark blue
Illumination RED / black
Left Front + Light green Line level output
Left Front - WHITE/ orange Line level output
Right Front + WHITE/ red Line level output
Right Front - Brown Line level output
Left Rear + Lt.blue/black Line level output
Left Rear - Yellow Line level output
Right Rear + PURPLE / white Line level output
Right Rear - Light blue Line level output
Lincoln amplified system wiring diagrams -- posted image. AMPLIFIER OUTPUTS
Wire FunctionColorNoteFuse #SizeLocation
12V DC BatteryLt.GREEN/ purple  10 20 amp Fuse box in engine compartment
Remote Turn On (input) Dark blue
Left Front Mid + Lt.GREEN / WHITE Splits to front door speaker & to rear speaker
Left Front Mid - Pink/lt.blue Splits to front door speaker & to rear speaker
Right Front Mid + BLACK/ lt.green Splits to front door speaker & to rear speaker
Right Front Mid - BROWN / pink Splits to front door speaker & to rear speaker
Right Front Tweeter + Dk.GREEN/ orange
Right Front Tweeter - WHITE/ lt.green
Left Rear Tweeter + Gray/lt.blue
Left Rear Tweeter - Tan / YELLOW
Right Rear Tweeter + WHITE/ purple
Right Rear Tweeter - ORANGE / red
Lincoln amplified system wiring diagrams -- posted image. AT SPEAKERS
Left Rear Mid + Lt.GREEN / WHITE
Left Rear Mid - Pink/lt.blue
Right Rear Mid + BLACK/ lt.green
Right Rear Mid - BROWN / pink
