01 Dodge Ram Diesel remote start diagram
Welcome Guest :)
martinezrp
Member -
Posted: November 07, 2006 at 9:28 PM / IP Logged
Does someone have a remote start wiring diagram for a 2001 Dodge Ram Diesel?
Platinum -
Posted: November 07, 2006 at 11:28 PM / IP Logged
| Dodge |
| Ram Pickup |
| 1999 - 2001 |
| | Remote Starter Wiring Colors and Notes | | Function | Vehicle Color | Location | | Start: | BLUE / YELLOW | | | Ignition #1: | D BLUE | IGNITION SWITCH HARNESS | | Ignition #2: | BLACK/ ORANGE | IGNITION SWITCH HARNESS (HEAT/AC) | | Ignition #3: | N/A | | | Accessory: | BLACK/ WHITE | IGNITION SWITCH HARNESS | | Brake Light: | WHITE/ TAN (+) | AT SWITCH ABOVE BRAKE PEDAL | | Tach Signal: | GRAY/L BLUE | AT POWERTRAIN CONTROL MODULE ** | | Parking Lights: | BLACK / YELLOW (+) | AT HEADLIGHT SWITCH **** | | Headlights: | LT. GREEN (+) | AT HEADLIGHT SWITCH | | Diesel Glow Plug: | ORANGE / BLACK | IN LARGE CONN. UNDER LEFT SIDE DR. DASH | | Clutch Bypass Wire: | | | | Notes: | * 2000 Vehicles may be equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems. ** Powertrain Control Module Located On Passenger Rear Of Engine On Firewall. | | Alarm and Keyless Entry Wiring Colors and Notes | | Function | Vehicle Color | Location | | Constant +12 Volts: | PINK/BLACK & RED | IGNITION SWITCH HARNESS | | OEM Alarm Disarm: | LT. GREEN/ ORANGE (-) | # PIN CONN. BEHIND DRIVER'S DASH ***** | | OEM Horn: | BLACK/ RED (-) | STEERING COLUMN HARNESS | | Power Lock: | ORANGE / VIOLET | BLACK 8 PIN CONNECTOR | | Power Unlock: | PINK/VIOLET | IN DRIVER'S KICK PANEL *** | | Trunk Release: | N/A | | | Alarm Input Wire: | YELLOW (-) | AT HEADLIGHT SWITCH ** | | Notes: | ** YELLOW (-) Wire Also Located In 8 Pin Black Connector Above Passenger Kick Panel. *** See Note Installation Note # 203 - Reverse Polarity Diagram For Unlock. See Note Installation Note # 202 - Positive Polarity Diagram For Lock. **** This Wire Can Be |
Wednesday, March 4, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
