keyless entry for 2002 Dodge Ram
dwh137
Posted: January 25, 2003 at 7:46 PM / IP Logged
I am trying to install a alarm system on a 2002 Dodge Ram. I would like to know what type of door lock system it has, and how to connect it so I can lock / unlock doors via remote control.
Platinum - Posts: 12,488
Posted: January 25, 2003 at 7:50 PM / IP Logged
|       POWER LOCK|WHITE/ green    |-  |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
Single wire system.
  • Lock requires a negative trigger thru a 820 ohm resistor. MUST use relay
  • Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relay
dwh137
Posted: January 26, 2003 at 10:10 AM / IP Logged
Thanks Jeff.
Do you happen to have a diagram on how to wire that up. I am not sure how the wires from the security system will be used to lock and unlock.
Posted: January 26, 2003 at 10:20 AM / IP Logged
http://www.velocitymotorsport.com/images/install_notes/N2N.jpg
Go to the above link and use the diagram there to wire up the resistors on pin 30 of each lock/unlock relay. If the alarm system has alternating polarity lock/unlock wires, then set it up for (-) because the diagram is for a (-) activation.
