2000 Toyota Echo Alarm/Remote Start Wiring
t_26dragon
Posted: December 27, 2006 at 9:13 PM / IP Logged
Hello I would like to know if u have a wiring diagram for a 2000 Toyota Echo if so that would be great.
Thanks Travis
Email  m_shelly22@yahoo.com
KarTuneMan
Platinum - Posts: 7,056
Posted: December 28, 2006 at 9:44 AM / IP Logged
 Wire/Function Colour Location/Description Polarity
 12 VOLTS WHITE/ red or WHITE/ blue Ignition switch harness   +
 IGNITION BLACK/ red Ignition switch harness   +
 IGNITION 2 BLACK / YELLOW Ignition switch harness   +
 ACCESSORY Runs with ignition
 STARTER Black (small gauge) Ignition switch harness   +
 You may need to isolate the starter wire from the ignition switch when doing a remote starter to prevent it from feeding back and engaging the starter when the key is turned on. See the TIP diagram.
 KEY SENSE Yellow At ignition switch harness   -
 TACH SIGNAL SEE NOTES Top of engine   AC
 Remove plastic engine cover to expose 4 coils. Each coil has a 4-wire plug with 3 of the wire colors common to all 4 coils. Use the odd color at any of the coils for a 1-cylinder reference signal.
 FUEL INJECTOR Opposite from BLACK/ red At any injector on engine   AC
 LOCK BROWN / yellow On 14-pin plug in DKP   -
 UNLOCK GREEN/ black & Blue/red On 14-pin plug in DKP   -
 Equipped with Toyota's Child Safety Door-lock system. Both wires must be connected for doors to unlock properly. See the door-lock diagram for details.
 DOORPIN RED / white or Blue / YELLOW At Junction block in driver's side dash   -
 TRUNK PIN RED / blue At light in rear compartment   -
 FACTORY ARM BLACK/ red In harness from driver's door   -
 FACTORY DISARM Blue / YELLOW In harness from driver's door   -
KarTuneMan
BRAKESWITCH GREEN / WHITE At switch above brake pedal   +
 PARKLIGHTS GREEN/ sil. Dots At fusepanel or DKP   +
 HAND BRAKE Yellow/red 14-pin plug below radio in dash   -
 HORN WHITE/ red Ignition switch harness   -
 CLUTCH SWITCH WHITE/ black At switch on clutch pedal   TYPE 2
 DRIVER WINDOW UP Red At switch in driver's door   REV POL
 DRIVER WINDOW DOWN Green At switch in driver's door   REV POL
 PASSENGER WINDOW UP Blue/red In harness from driver's door   REV POL
 PASSENGER WINDOW DOWN Blue / YELLOW In harness from driver's door   REV POL
 LEFT REAR WINDOW UP RED / yellow In harness from driver's door   REV POL
 LEFT REAR WINDOW DOWN GREEN/ YELLOW In harness from driver's door   REV POL
 RIGHT REAR WINDOW UP RED / black In harness from driver's door   REV POL
 RIGHT REAR WINDOW DOWN GREEN/ black In harness from driver's door   REV POL
 HEADLIGHTS RED / blue At light switch harness   -
 REVERSE LIGHTS RED / yellow or RED / black At junction block in driver's dash   +
 DIMMER WHITE/ black At dimmer switch in dash   +
 VSS WIRE Violet/white Pin-9 of 22-pin plug on ECM
 These wires can also be found at the Factory alarm module on the right side of the steering column near the firewall.
