1995 Eagle Vision wiring
12VBob
Posted: February 03, 2003 at 6:14 PM / IP Logged
Install a remote starter on 1995 Eagle Vision and having problem locating the OEM alarm disarm (supposed to be light GREEN/ orange in drivers kick panel).  Any better descriptions about what harness this is in?  Hope it solves my problem if I hook this up. When the car is running and the door unlock is pressed it burns out the engine compartment fuse for the main ignition wiring. Please send any answers to bobk@westernsales.ca
Thanks, Bob
kickyride
Copper - Posts: 100
Posted: February 03, 2003 at 6:38 PM / IP Logged
Hi Bob,
It will be in the harness that comes in the car from the door. The disarm wire comes from a switch that is built into the door's key cylinder. Worst case, you should be able to access the wire in the door boot. Hope this helps.
Mike
Sales/Tech Support - KICKYRIDEoCOM mobile electronics
MECP 1st class-Security Specialist
Platinum - Posts: 12,488
Posted: February 03, 2003 at 6:48 PM / IP Logged
|              12V|pink/black,red (20A)|+  |ignition harness            |
|          STARTER|yellow/gold dots    |+  |ignition harness            |
|         IGNITION|dk. blue/gold dots  |+  |ignition harness            |
|  SECOND IGNITION|RED / wht/gold dots   |+  |ignition harness            |
|   THIRD IGNITION|*3                  |   |                            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
|       POWER LOCK|ORANGE / white *1     |+  |wht plug back of fuse panel |
|     POWER UNLOCK|pink/purple *1      |+  |wht plug back of fuse panel |
| PARKING LIGHTS +|BLACK / YELLOW        |   |driver kick panel           |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|green               |+  |headlight switch            |
|     DOOR TRIGGER|tan & tan/red *2    |-  |driver kick panel           |
|  TRUNK/HATCH PIN|BROWN / black         |-  |driver kick panel           |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at switch                   |
|  FCTRY ALARM ARM|lock                |   |                            |
|FCTRY ALRM DISARM|lt.GREEN/ orange 20ga|-  |either kick                 |
|       TACHOMETER|red, white, or black|   |at coil pack                |
|       BRAKE WIRE|white               |+  |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |-  |relay in fuse panel         |
|           WIPERS|pink                |+  |3 wire plug near wiper motor|
|  LF WINDOW UP/DN|lt.blu/gld - wht/gld|A  |in driver door              |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |in driver door or dkp       |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |in driver door or dkp       |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |in driver door or dkp       |
Notes:
*1 Also find same colors in harness to right of glove box by passenger kick panel.  *2 Tan gets drivers door, tan/red gets pass. doors. Tap both wires and diode isolate.  *3 The SRS (air bag) warning light may come on after remote started, after the key is inserted and the remote start shut down with the brake. If this happens, find an 18ga (NOT 12ga) RED / white in the ignition harness. Power it as an Ign 3 with an additional relay.
12VBob
Posted: February 06, 2003 at 6:51 PM / IP Logged
Have tried to locate wire but am unsuccessful. Have even removed door panel and only one thick GREEN/ red-orange 10-12 gauge wire is there and found to be for the windows.  Found another GREEN/ red-orange in lower kick panel harness. It has pulses when locks are pushed but hooking directly to this did not work with the (-) disarm off the remote starter unit (autostart as-6105 SH/SR).  No wires come from the lock cylinder itself, but there are some from the latch mechanism.  Would one of these be the correct wire?
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
