03 f350 alarm/remote start wiring
mister_k
Posted: April 23, 2007 at 1:55 PM / IP Logged
Need Direct wire for 03 F350 SuperDuty, and DirectFax document #1093, please and thank you
wire4veins
Copper - Posts: 97
Posted: May 03, 2007 at 11:15 PM / IP Logged
Here is the info you requested:
12volts      yellow & lt. GREEN/ purple       +       ignition harness
Starter      green       +       ignition harness
Second Starter      N/A
Ignition      RED / lt. green or WHITE/ yellow       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      gray / YELLOW & RED / black       +       ignition harness
Second Accessory      blue/lt. green       +       ignition harness
Keysense
Power Lock
Notes: Without keyless entry use pink / YELLOW for lock and pink/lt. green for unlock. They are 5 wire reverse polarity mastered from the driver switch and found in either kick panel. With keyless entry use WHITE/ red for lock and BLACK/ white for unlock. They are negative trigger and found at the VSM.
Power Unlock
On the vehicles with keyless entry the GEM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motor      pink/black       5wi      VSM
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor      RED / orange       5wi      VSM
Parking Lights+      brown       +       headlight switch
Parking Lights-      N/A
Hazards      same as turn signals
Turn Signal(L)      lt grn/wht (F), lt grn/org (R)      +       steering column
Turn Signal(R)      wht/lt blu (F), org/lt blu (R)      +       steering column
Reverse Light      BLACK/ pink       +       fuse box
Door Trigger      BLACK/ lt. blue       +       passenger kick panel
Dome Supervision      use door trigger
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer      NOT RED / lt. green       ac       any ignition coil
Notes: On diesel vehicles the tach wire is GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release. The tach wire on these vehicles may generate an unclean signal. Options maybe to set the threshold jumper to “on/low“ when programming tach in some Directed remote systems or use part number 454T tach signal generator.
Wait to start      see DirectFax document 1091
Notes: On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire      lt. green       +       brake pedal switch
Parking Brake      lt. GREEN/ red       -       parking brake switch
Horn Trigger      blue       -       steering column or VSM
Memory Seat 1      BROWN / lt. green       -       memory mod under dr seat
Memory Seat 2      BLACK/ orange       -       memory mod under dr seat
Memory Seat 3      N/A       -
1093 Link
wire4veins
"D"
Precision Autosound - Owner
MECP Master Installer
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
