2004 Pontiac Grand Prix Alarm/Remote Start/Stereo Wiring
waznis13
Posted: June 08, 2007 at 12:20 PM / IP Logged
Need wiring diagram for a 2004 Pontiac Grand Prix. Need one for the alarm and stereo. The one that is listed now has a link that does not work. Thanks for any help!
rudydapimp
Copper - Posts: 390
Posted: June 09, 2007 at 5:09 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / GRAND PRIX / 2004 / Remote Start
[PRINT THIS PAGE]
12volts      red (50A), red (40A) + back of fuse box, passenger dash
Starter      yellow + ign harn or BCM, conn. C1, pin 21
Notes: The BCM (Body Control Module) is below the driver side dash to the left of the steering column.
Second Starter      N/A
Ignition pink       + ign harn or BCM, conn. C1, pin 22
There are two pink wires in the BCM plug that meter as ignition. To verify that the correct wire is being energized for remote start, slide the key in the ignition key cylinder and then activate remote start. If the key in ignition warning chime comes on, then the correct wire is being energized.
Second Ignition      N/A
Third Ignition      N/A
Accessory brown + ign harn or BCM, conn. C1, pin 23
Second Accessory      N/A
Keysense lt. green - ign harn or BCM, conn. C1, pin 40
If the service security lights comes on during remote start or after key takeover, see DirectFax document 1502.
Power Lock RED / black -       BCM, conn. C2, pin 2
Power Unlock ORANGE / black - BCM, conn. C2, pin 11
Lock Motor      gray       5wi      BCM, conn. C2, pin 52
Unlock Motor      tan       5wi      BCM, conn. C2, pin 46
Parking Lights+      brown       +       front of fuse box, passenger dash
Parking Lights-      BROWN / white       -       BCM, 18 pin plug, pin 8
Hazards      tan       -       BCM, 18 pin plug, pin 16
Turn Signal(L)      use hazards wire
Turn Signal(R)      use hazards wire
Reverse Light      lt. green       +       BCM, conn. C2, pin 42
Door Trigger      see notes       -       BCM, conn. C2
Notes: The driver door trigger is gray/black in pin 26, the front passenger door is BLACK/ white in pin 17, the left rear door is lt. blue/black in pin 7, and the right rear door is lt. GREEN/ black in pin 5. Use all four wires and diode isolate each.
Dome Supervision      gray/black       +       BCM, conn. C1, pin 43
Trunk/Hatch Pin      RED / black       -       BCM, conn. C2, pin 3
Hood Pin      N/A
Trunk/Hatch Release      lt. blue       +       BCM, conn. C2, pin 45
Power Sliding Door      N/A
Factory Alarm Arm      lt. green       -       BCM, conn. C2, pin 22
Factory Alarm Disarm      purple       -       BCM, conn. C2, pin 24
Disarm No Unlock      see factory alarm disarm
Tachometer      white       ac       ignition control module, pin E
Notes: The ignition control module is on top of the engine towards the passenger side.
Wait to start      N/A
Brake Wire      white       +       BCM, conn. C2, pin 30
Parking Brake      ORANGE / black       -       BCM, conn. C2, pin 9
Horn Trigger      black       -       BCM, conn. C1, pin 4
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
PASS-Key III
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
rudydapimp
Copper - Posts: 390
Posted: June 09, 2007 at 5:10 AM / IP Logged
Radio 12v      orange       +       radio harness
Radio Ground      BLACK/ white       -       radio harness
Radio Ignition      (Class 2 Serial Data)
Radio Illumination      gray (dimmer)       +       radio harness
Factory Amp Turn-on      same as power antenna wire
Power Antenna      purple       +       radio harness
LF Speaker +/-      tan - gray       +,-      radio harness or amplifier
Notes: The amplifier is under the rear deck.
RF Speaker +/-      lt. green - dk. green       +,-      radio harness or amplifier
LR Speaker +/-      brown - yellow       +,-      radio harness or amplifier
RR Speaker +/-      dk. blue - lt. blue       +,-      radio harness or amplifier
waznis13
Posted: June 09, 2007 at 1:07 PM / IP Logged
Thank you so much. This will help immensely!
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
