2008 Ford F-450 Alarm/Remote Start Wiring
marcosbmonzon
Posted: July 20, 2007 at 4:14 PM / IP Logged
does anyone know wiring diagram for a 2008 ford f450 with a 5.4 diesel
mikvot
Gold - Posts: 1,043
Posted: July 20, 2007 at 5:15 PM / IP Logged
12volts
  blue/red (x2)(common 20A)
  ignition harness
Starter  blue/white   +   ignition harness
Second Starter  N/A
Ignition  WHITE/ orange   +   ignition harness
Second Ignition  N/A
Third Ignition  N/A
Accessory  BROWN / yellow   +   ignition harness
Second Accessory  PURPLE / green   +   ignition harness
Keysense  blue/lt. gray   +   ignition harness
Power Lock  blue/lt. green   -   driver kick, door harness
Power Unlock  yellow/purple   -   driver kick, door harness
Lock Motor
Unlock Motor  PURPLE / gray   5wi  driver kick, door harness
Parking Lights+  PURPLE / white   +   SJB, conn. D, pin 20
Parking Lights-  gray   -   headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light  GREEN/ brown   +   harness to rear
Door Trigger  see notes   -   each kick or SJB, conn. C
Dome Supervision  yellow/gray   +   SJB, conn. A
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer  blue/white   ac   PCM or Customer Access Point
Wait to start  see DirectFax document 1091
Brake Wire  PURPLE / white   +   brake pedal switch
Parking Brake  WHITE/ purple   -   switch or SJB, conn. C, pin 1
Horn Trigger  yellow/red   -   horn switch
Memory Seat 1  PURPLE / white   -   driver kick, door harness
Memory Seat 2  yellow   -   driver kick, door harness
Memory Seat 3     -
marcosbmonzon
Posted: July 21, 2007 at 12:51 PM / IP Logged
thanks alot for your help
mikvot
Gold - Posts: 1,043
Posted: July 21, 2007 at 8:07 PM / IP Logged
No prob....for your info, the the sjb is in the passenger kick panel, but i've done quite a few alarms on these, and i catch the locks and park lights(+) in the drivers kick, and the dome light (delayed) can be found in the drivers door sill, behind drivers seat where harness t's behind the seat. I've never gone to pass. side for anything.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
