1998 Chevrolet C/K pickup
godsegoizhuge
Copper - Posts: 214
Posted: February 16, 2003 at 6:13 PM / IP Logged
Hi, I was wondering if someone could send me the wiring diagrams so I can install a remote starter. Thank you for the help.
jayts95
Copper - Posts: 150
Posted: February 16, 2003 at 7:09 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|yellow or purple    |+ |ignition harness            |
|        IGNITION|pink               |+ |ignition harness            |
| SECOND IGNITION|white *5            |+ |ignition harness            |
|   THIRD IGNITION|pink/white *1       |+ |ignition harness            |
|        ACCESSORY|orange              |+ |ignition harness            |
|       POWER LOCK|lt. blue            |*2 |either door boot            |
|     POWER UNLOCK|white               |*2 |either door boot            |
|       LOCK MOTOR|gray               |   |drivers kick panel          |
|     UNLOCK MOTOR|tan                 |   |drivers kick panel          |
|    DISARM DEFEAT|tan                 |   |passengers kick panel       |
| PARKING LIGHTS +|brown               |   |switch or fuse panel        |
|       HEADLIGHTS|yellow              |+ |at switch                   |
|     DOOR TRIGGER|purple or ppl/wht   |- |light switch               |
|       TACHOMETER|white *3            |   |ECM *4                      |
|       BRAKE WIRE|white               |+ |at brake pedal switch       |
|     HORN TRIGGER|black               |- |at column                   |
|           WIPERS|purple              |+ |steering column             |
| LF WINDOW UP/DN|dk. blue - brown    |A |at drivers door switch      |
| RF WINDOW UP/DN|light blue - tan    |A |drivers door or boot        |
| LR WINDOW UP/DN|green - purple      |A |drivers door or boot        |
| RR WINDOW UP/DN|lt. grn - pur/wht   |A |drivers door or boot        |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The pink/white does not exist on all models.   *2 5 wire (type C) on the two door models, and positive trigger (type A) on the four door and keyless entry models. *3 Tach wire on the 6.5 Diesel is white at the instrument cluster. Diesel wait to start wire is dk. blue (-) located at the instrument cluster 'see directfax document #1090'. *4 ECM located on drivers side inner fender well. Two plugs, white wire in plug marked 'white'. *5 Make sure to enable second ignition wires for remote starts to prevent possible transmission damage and the check engine light from coming on.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
