2007 ford ranger alarm wiring
edblo
Posted: September 15, 2007 at 6:31 AM / IP Logged
Can someone pls help me with the new 2007 ford Ranger alarm wiring. I found some of it on the convenience module pass side, can't find lock wire and door trigger.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 15, 2007 at 7:11 PM / IP Logged
LOCK Violet/gray In Gray and Black connector above handbrake near firewall   -
 Can also be found in center plug on passenger side fusebox in passenger kickpanel
 UNLOCK Gray / YELLOW In Gray and Black connector above handbrake near firewall   -
 DOORPIN SEE NOTES
 Driver's door (GREEN/ purple), right front door (White), left rear door (Green) and right rear door (Yellow). All 4 wires are found in the passenger kickpanel on the fusebox. Driver's door is in the center plug and all other doors are in the top plug. Diode isolate
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
