2001 impala radio wiring diagram
fred25tt
Posted: October 24, 2007 at 8:24 PM / IP Logged
I have a 2001 Impala and I am trying to find out which wire in the factory radio wiring harness I tap into to get a switched 12v signal.  I am trying to run an aftermarket amp.  Also, I have the factory amp system, and I am installing the PAC-GM24.  Everything is pretty easy except for finding which wire I tap into to run the remote on/off for the amp.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 26, 2007 at 9:25 AM / IP Logged
Im not sure about the GM-24, I would use the peripheral part# SVENR
creates a turn signal on when audio signal is senced.
midnightdenizen
Member - Posts: 17
Posted: November 10, 2007 at 8:31 PM / IP Logged
I usually run a wire to the fusebox to grab ingnition in that car. There is no ACC wire in the harness.
Billy Smith
