2007 econoline e150, remote start wiring
Welcome Guest :)
illness98
Member -
Posted: October 29, 2007 at 4:59 PM / IP Logged
I need wiring info for a 2007 Ford E150, for a remote start.. Please and thank you
KarTuneMan
Platinum -
Posted: October 30, 2007 at 1:16 AM / IP Logged
| 12 VOLTS | Yellow | Ignition harness | + |
| IGNITION | RED / green | Ignition harness | + |
| | | There are 2 wires of this color present, they are common. |
| ACCESSORY | Gray / YELLOW | Ignition harness | + |
| ACCESSORY 2 | BLACK/ green | Ignition harness | + |
| STARTER | WHITE/ pink | Ignition harness | + |
| KEY SENSE | BLACK/ pink | Ignition harness | - |
| TACH SIGNAL | See notes | | |
| | | On the 4.2L use PINK/WHITE at the coil or the pin-78 at the PCM (2 cylinder signal). On the 4.6L use the PINK/WHITE at the left side coilpack or pin-78 at the PCM (2 cylinder signal). On the 5.4L use WHITE/ PINK at pin-78 of the PCM (1 cylinder signal). On the 6.8L use WHITE/ RED at pin-79 of the PCM (1 cylinder signal). The PCM is located on the left rear side of the engine compartment near the brake master cylinder. |
| DIESEL TACH SIGNAL | WHITE/ pink | At pin-1 of top plug on PCM | AC |
| | | The PCM is found in the left rear side of the engine compartment near the brake master cylinder. Can also use Dk.blue/gray (crank sense wire) at pin-30 of the same plug. |
| LOCK | Red | Passenger kickpanel | Rev Pol |
| | | If the van is equipped with keyless entry, the doorlocks will be positive pulse. The wire colors will be PINK / YELLOW for lock and PINK/GREEN for unlock. |
| UNLOCK | Brown | Passenger kickpanel | Rev Pol |
| DRIVER LOCK MOTOR | Pink/black | In driver's kickpanel | + |
| DRIVER UNLOCK MOTOR | RED / orange | In driver's kickpanel | + |
| PASSENGER UNLOCK MOTOR | Pink/orange | In passenger kickpanel | + |
| GLO-PLUG SIGNAL | DATA ONLY | USE DELAY TIMER | |
| DOORPIN | BLACK/ blue | In driver's kickpanel | + |
| TRUNK PIN | Common with doors | If equipped with pinswitch | |
| TRUNK RELEASE | Manual release | | |
| BRAKESWITCH | Green | At switch above brake pedal | + |
| PARKLIGHTS | Brown | At light switch or DKP | + |
| HAND BRAKE | Lt.GREEN/ red | At plug on handbrake lever | - |
| HORN | Blue | At steering column | - |
illness98
Member -
Posted: October 30, 2007 at 10:59 AM / IP Logged
Monday, April 20, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
